PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup
I have created multiple videos on setting up a PinePhone and/or PinePhone Pro with DanctNIX Arch Linux Arm.
PinePhone (1of5) - Flash DanctNIX Arch with Phosh
https://www.youtube.com/watch?v=XNF8zuIE...99&index=8
00:00 Intro
00:20 Insert SD card
01:00 Download jumpdrive
02:00 unzip jumpdrive
03:00 umount SD card
04:10 flash jumpdrive to SD card
05:50 remove SD from computer
06:30 Download Arch Linux
06:45 Turn off the phone
07:30 unzip Arch Linux
08:00 install Jumpdrive SD into phone
09:00 plug phone into computer
09:10 turn on the phone
09:45 umount the emmc
11:15 flash Arch Linux to emmc
12:45 turn off the phone
13:45 remove SD card
14:15 turn on the phone
15:30 Password 123456
PinePhone Pro (1of5) - Flash DanctNIX Arch with Phosh
https://www.youtube.com/watch?v=FBGVUq3D...99&index=3
00:00 Intro
00:20 Download image
01:05 uncompressed image
02:20 Turn on phone
03:30 unmount phone
04:25 dd the image
07:10 Reboot the phone
08:40 DONE!
PinePhone OR PinePhone Pro (2of5) - Phosh - Setup - Updates - Packages
https://www.youtube.com/watch?v=-nbUXABJ...99&index=4
00:00 Intro
00:25 enable ssh
02:38 Change password
03:45 remove "show all apps"
04:18 Screen Scaling
05:45 Update Arch
10:30 Remove unused packages
11:05 Mount Network drive
12:45 Packages
13:05 Install gedit
13:30 Install pcmanfm
15:40 Custom Packages
17:45 Install wayvnc-git
20:20 Install aspell aspell-en
20:40 Configure gedit (spell checker)
22:15 Install gnome-screenshot
23:15 Configure pcmanfm
28:00 Change desktop Icon
PinePhone OR PinePhone Pro (3of5) - Phosh - Setup - Syncthing - Squeekboard - Online Accounts
https://www.youtube.com/watch?v=esOT5PhC...99&index=5
00:00 install Syncthing
03:00 Start syncthing
03:55 Add network computer
04:48 Share the Downloads folder
06:10 add a syncthing desktop icon
10:30 G o o g l e account
12:30 Set key ring password
14:15 calendar sync
14:40 email sync
15:00 Local contacts and calendar sync with syncthing
16:00 Should have just restarted the phone...
19:00 install evolution to trouble shoot.
20:50 just restart the phone
21:30 update the squeekboard layout
PinePhone OR PinePhone Pro (4of5) - Phosh - Setup - Biktorgj - osmin - brave
https://www.youtube.com/watch?v=QgFtFzPh...99&index=6
00:00 Intro
00:10 Log into phone
00:28 install gnome-firmware
01:00 run gnome-firmware
03:20 Fail, Run again
04:20 Downgrade again
05:55 Biktorgj is loaded
06:30 verify the ADSP version
08:00 ... Thinking
08:05 DanctNIX tweaks app
08:10 Power
09:05 Set a background image
11:45 install wrong app...
13:55 install phosh-mobile-settings
14:40 phosh-mobile-settings
15:45 set the calendar on lock screen
17:15 Looking for power profile to sync calendars...
22:30 PinePhone verse PinePhone Pro Power
24:30 phosh-ticket-box set the folder to look in
26:15 Restart phone to see new lock screen
28:00 install osmin - Navigation app
29:40 running osmin
31:00 Try to copy already downloaded maps...
32:30 install sayonara-player
32:45 run sayonara-player
38:15 running osmin again with maps
41:25 install brave - browser
42:30 run brave browser
PinePhone OR PinePhone Pro (5of5) - Phosh - Setup - Chatty - SIM Card - SMS - MMS - Bible
https://www.youtube.com/watch?v=i10sj2WK...99&index=7
00:00 ssh
01:20 Copy Chatty files to phone
02:30 All conversations are on Chatty
03:00 Pull SIM card out of OG PinePhone
04:15 Pull apart PinePhone Pro
05:50 Service???
07:00 It Works!!!
07:40 APN settings
09:30 4G data works
09:55 Test Chatty SMS
10:30 Test 4G data
11:45 APN again???
12:50 3rd time is the charm!
13:30 SMS setup EDIT: MMS setup
15:00 Test MMS
16:00 MMS work!
16:20 bible_gui (Bible App)
18:45 run bible_gui
19:20 Download bible translations
23:00 Add translation
24:00 "~/share/net.lugsole.bible_gui/translations"
25:30 Play the Bible
26:10 Remove unwanted "desktop" icons
27:30 LEAVE A COMMENT!!!
I have both a PinePhone and PinePhone Pro. Are there any videos you would like to see?
Awesome and thanks. Smile
(05-07-2023, 10:06 PM)mikehenson Wrote: I have created multiple videos on setting up a PinePhone and/or PinePhone Pro with DanctNIX Arch Linux Arm.
00:00 Intro
00:00 Intro
02:20 Turn on phone
03:30 unmount phone
04:25 dd the image
08:40 DONE!
00:00 Intro
00:25 enable ssh
05:45 Update Arch
12:45 Packages
13:05 Install gedit
14:15 calendar sync
14:40 email sync
00:00 Intro
08:00 ... Thinking
08:10 Power
29:40 running osmin
00:00 ssh
05:50 Service???
07:00 It Works!!!
07:40 APN settings
09:30 4G data works
10:30 Test 4G data
11:45 APN again???
15:00 Test MMS
16:00 MMS work!
18:45 run bible_gui
First of all, thanks a lot. This is best "Bootcamp" setup material i've ever seen so far for PPPro Smile Could you make a video for example how to recover from failed installation of that firmware update when the modem is not bootable anymore? Smile Thanks!
This is the answer to nearly all PPp modem problems.
https://themodemdistro.com/efs_recovery
As long as you can get some access to the modem you do not need to short pins or open the phone. Remember to use sudo su to get a root shell rather then running the ADB, modemdistro scripts, and fastboot with sudo which often doesn't work.
Recovery of the EFS area
So, you're probably here because your modem suddenly stopped booting after a failed firmware ugrade or downgrade.
Long story short: something changed in the way Quectel builds their images and it seems like if you got a new board and attempt to flash an older image version the modem will stop being able to read its own EFS area and end up in offline mode with no IMEI.
Since most forum posts send everyone to the git we still have these problems because themodemdistro gid doesn't have any easy links to themodemdistro website where all of the good information is found.  Someone please update pine64 and mobian wikis as I have lost access.
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,104 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  Pinephone with KDE Plasma stuck at K logo after update Daniello 0 2,199 06-20-2024, 01:52 AM
Last Post: Daniello
  Pinephone error system-generators/ostree-system-generator failed with exit status 127 Daniello 3 4,075 06-15-2024, 03:38 AM
  Updating Arch Linux _radv_ 8 9,502 02-20-2024, 09:35 AM
Last Post: _radv_
  How to install arch with FDE user641 3 5,855 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 9,002 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 9,309 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 3,937 07-29-2023, 08:27 AM
Last Post: alpineduck
  unable to install applications dln949 5 7,564 06-08-2023, 08:38 PM
Last Post: Conjada
  Latest update broke my install user641 8 10,958 02-22-2023, 05:54 AM
Last Post: gregb49
