Manjaro Plasma blinking cursor
I have tow-boot on my SPI... I previously had Manjaro Plasma on the eMMC (I flashed it on there last year).
I put PostmarketOS on there (thinking it would fix the close lid, won't wake up issue) but has the same problem.
I try to put Manjaro 23/22 back on the eMMC (and SD card) and it is just stuck at the blinking cursor.
Wondering if anyone has dealt with this recently vs. from 2020.
tried 22.06 thinking older may work, this one flashing cursor as well and alternating green/red led
An update on this, I think it was the sd card I was using (128GB gold sandisk) vs. (32GB grey sandisk)
Mostly though I just had to wait for the logo to come up.
It's working now though.
I had pmos on emmc and I booted manjaro kde plasma 23.02 on grey sd card, downloaded and dd'd onto emmc.
rebooted, waited few seconds blinking cursor then manjaro logo showed up
I had to laugh as I had a bad 128GB Sandisk sd card this past week leave me at that screen over and over again till I figured out it was the card too. Glad you got it fixed.
Is that the reason it didn't work? 128GB is too big?
(05-06-2023, 07:01 PM)jcun4128 Wrote: Is that the reason it didn't work? 128GB is too big?
No I don't think so.  My card actually died.  It was just a bit of odd luck that amused me.
  Manjaro versions bad and good gilwood 0 2,676 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 10,776 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 4,910 12-13-2023, 08:17 PM
Last Post: trillobite
  Blinking Tiny Blue Indicator Light? ArchiMark 3 4,523 06-30-2023, 03:15 PM
Last Post: Samurai_Crow
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 484,139 05-12-2023, 06:09 AM
Last Post: korreckj328
  PBP blank screen after updating Manjaro Franko 6 7,717 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 2,138 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 11,489 02-06-2023, 09:11 AM
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 13,743 01-22-2023, 10:05 PM
Last Post: rfm83
  No boot after Manjaro flash PBcurry 14 15,474 10-03-2022, 08:33 PM
