PinePhone won't boot after software update
I have a Beta Edition PinePhone that I've been using since November of last year. I installed Mobian on the SD card (and also installed Tow-Boot as now required) and outside some minor hiccups have been fairly pleased with the experience. This past Sunday I did a routine software update from within GNOME Software and after resetting following the installation of updates the PinePhone would no longer boot. The LED still turns cyan after I hold the volume-down button to boot from the SD card (as is the case after Tow-Boot is installed) but shortly afterwards turns off and just reboots itself. I'm still able to browse the files on the SD card from a desktop and I'm still able to boot operating systems on other SD cards and from the eMMC meaning the issue is with this particular installation itself.
Frankly I have no idea where to begin in solving this issue. Is there a key I can press on an attached physical keyboard when booting to try and recover the system? Maybe some sort of recovery media I can load somehow? Any insight or recommendations on how to restore this installation would be appreciated.
(03-16-2023, 02:14 AM)jb2000 Wrote: I have a Beta Edition PinePhone that I've been using since November of last year. I installed Mobian on the SD card (and also installed Tow-Boot as now required) and outside some minor hiccups have been fairly pleased with the experience. This past Sunday I did a routine software update from within GNOME Software and after resetting following the installation of updates the PinePhone would no longer boot. The LED still turns cyan after I hold the volume-down button to boot from the SD card (as is the case after Tow-Boot is installed) but shortly afterwards turns off and just reboots itself. I'm still able to browse the files on the SD card from a desktop and I'm still able to boot operating systems on other SD cards and from the eMMC meaning the issue is with this particular installation itself.
Perhaps I am wrong, but I think your installation may be definitely broken.
I have this doubt: what occurs if while updating, they are uploading files? Don't know, but to avoid this I decided to do the updates only on Monday, once a week.
I perform periodic full image backups of the eMMC so that if updates go horribly wrong the phone can be easily returned to a working state. Also I keep a "known to work" SD card handy to boot from, just in case.
I've thought about just not doing updates at all since the phone has worked well enough for my needs for some time now. I keep hoping though that some of the rough edges will get polished at some point, so for now I still do updates once or twice a week.
  Mobian image for the PinePhone Korfou 2 1,975 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,916 12-24-2025, 12:11 AM
  No touch KB after update(forky) biketool 4 2,726 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 3,288 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 74,774 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 353,580 06-25-2025, 01:19 PM
  Mobian Pinephone Notification LED biketool 2 4,437 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,249 02-20-2025, 02:47 PM
Last Post: puffchumpy
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,601 01-02-2025, 12:47 PM
Last Post: zetabeta
  how to update mobian over tor vusra 14 20,715 12-04-2024, 07:01 PM
Last Post: vusra
