New Phone Opening Issues
recently received Pine64 Beta.  Went through the quick start guide which was fine until I got to this issue:
  • If the phone is plugged on charge it works perfectly, the screen is visible and functional.
  • But, if the phone - even if fully charged - is not plugged in, the screen fades to black in about less than second.  Touch the screen it opens, but it's barely enough time to choose either a number for the pin code or to tap an app icon.  It's functional but it so fast as disappearing, that the area of the screen being tapped is 'hit and miss'.  If that makes sense.
I've checked the battery is in correct, and I've done a reset in hopes it was a glitch, but still happening.  Simply put - can't see the screen for more than a blink of an eye.  I've not put in a sim card nor changed the operating system since I can't really see the screen and the options to start using the phone.
Any help appreciated
thanks
Lulu
this seems familiar, vaguely.
try leaving it plugged in, entering the pin, and then go through the settings (maybe in a pull down menue from the top of the screen or a pull up menu from the bottom, or a menu/ widget you can click on) to find something for the screen time out. I'll bet they are different for when it's plugged in and when it's running from the battery (where its probably set to like 2sec).
sorry i'm not more exact in my explanation. I stopped using manjaro soon as i could.
hope that helps
(02-24-2023, 12:38 PM)_radv_ Wrote: this seems familiar, vaguely.
hope that helps
Thanks, it does make sense.  I'll give it a try.
Personally, I advise you to use another operating system, I had many problems with it as you can see:
https://forum.pine64.org/showthread.php?tid=17745
(02-28-2023, 12:40 PM)anonymous Wrote: Personally, I advise you to use another operating system, I had many problems with it as you can see:
I had come to this conclusion.  I've got it sitting on my desk with a SD card on my to do list today.
Thank you!
Thank you!
You're welcome. I'm from France too. Don't hesitate to ask questions. I highly encourage you to install Tow-Boot and to pick a supported distribution. It's very straightforward. Maybe this helps:
https://wiki.mobian-project.org/doku.php?id=tow-boot
  Default password for KDE plasma pine phone Toni 0 8,415 09-14-2025, 06:35 PM
Last Post: Toni
  BalenaEtcher issues... gtamichael 6 5,631 03-26-2025, 09:22 AM
Last Post: gtamichael
  My new phone stopped working. gunnygee 3 4,881 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,361 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,432 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 6,879 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 9,308 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 13,026 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,814 01-09-2024, 07:02 PM
Last Post: britelite
  Multiple issues with the Pinephone MTXP 12 13,720 12-28-2023, 07:55 AM
Last Post: MTXP
