Can't complete update of manjaro: wwan0 stays disabled; no phone/text
I started an upgrade and am unable to complete it.
To even see the relevant iface (and confirm it failed to grab an IP), I had to do
ifconfig wwan0 up ifconfig wwan0
The modem is "disabled", and I do not know how  to enable it.
mmcli -m any | grep state            |                   state: disabled            |             power state: off            |    packet service state: detached nmcli r wifi on mmcli -m any | grep state            |                   state: disabled            |             power state: off            |    packet service state: detached
Now, my PPP lacks phone and internet .
Everything other than the modem (including WiFi, but not bluetooth, which I will comment on separately if need be) seems fine, so far.
Here is what I see when I answer the default Y, to all save libgpiod,
:: libgpiod1 and libgpiod are in conflict. Remove libgpiod? [y/N] error: unresolvable package conflicts detected error: failed to prepare transaction (conflicting dependencies) :: libgpiod1 and libgpiod are in conflict
Answering Y, gives,
:: libgpiod1 and libgpiod are in conflict. Remove libgpiod? [y/N] Y error: failed to prepare transaction (could not satisfy dependencies) :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kdav2 :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kimap2 :: removing kcontacts breaks dependency 'kcontacts' required by kpeoplesink :: removing kpeople breaks dependency 'kpeople' required by kpeoplesink :: removing kcontacts breaks dependency 'kcontacts' required by sink :: removing kcalendarcore breaks dependency 'kcalendarcore' required by sink
When I try to remove the culprits, I have the following.
looking for conflicting packages... warning: removing 'libgpiod' from target list because it conflicts with 'libgpiod1' :: libgpiod1 and libgpiod are in conflict. Remove libgpiod? [y/N] y error: failed to prepare transaction (could not satisfy dependencies) :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kdav2 :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kimap2 :: removing kcontacts breaks dependency 'kcontacts' required by kpeoplesink :: removing kpeople breaks dependency 'kpeople' required by kpeoplesink :: removing kcontacts breaks dependency 'kcontacts' required by sink :: removing kcalendarcore breaks dependency 'kcalendarcore' required by sink
From the forum, I found
New PinePhone user issues - https://forum.pine64.org/showthread.php?...#pid123017
Pacman update cannot resolve plasma-mobile dependencies. · Issue #75 · manjaro-pinephone/plasma-mobile · GitHub — https://github.com/manjaro-pinephone/pla.../issues/75
I recently posted something as detailed as possible about this on the pine64 forum: (See above)
To sum up:
You need to delete all foreign packages at once with the following two commands:
pacman -Qmq > list.txt
pacman -R - < list.txt
(Be careful to sort out the packages that have been installed by the user from the AUR)
Then, of course, you need to remove the orphaned packages.
So guided, I tried removing each of the culprits. (I did not want to remove anything not required.)
pacman -R kcoreaddons checking dependencies... error: failed to prepare transaction (could not satisfy dependencies) :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kactivities :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kalk :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kauth :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kcontacts <--SHOULD DO 2nd :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kcrash :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kdav2 :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kdesignerplugin :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kfilemetadata :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kimap2 :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kjobwidgets :: removing kcoreaddons breaks dependency 'kcoreaddons' required by knotifications :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kpackage :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kpeople :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kpipewire :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kpty :: removing kcoreaddons breaks dependency 'kcoreaddons' required by krecorder :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kservice :: removing kcoreaddons breaks dependency 'kcoreaddons' required by kweather :: removing kcoreaddons breaks dependency 'kcoreaddons' required by qmlkonsole pacman -R kcontacts checking dependencies... error: failed to prepare transaction (could not satisfy dependencies) :: removing kcontacts breaks dependency 'kcontacts' required by kpeoplesink <--REMOVE WITH kpeople, 1st :: removing kcontacts breaks dependency 'kcontacts' required by kpeoplevcard <--REMOVE WITH kpeople, 1st :: removing kcontacts breaks dependency 'kcontacts' required by libkgapi :: removing kcontacts breaks dependency 'kcontacts' required by plasma-dialer :: removing kcontacts breaks dependency 'kcontacts' required by plasma-phonebook :: removing kcontacts breaks dependency 'kcontacts' required by sink :: removing kcontacts breaks dependency 'kcontacts' required by spacebar pacman -R kpeople checking dependencies... error: failed to prepare transaction (could not satisfy dependencies) :: removing kpeople breaks dependency 'kpeople' required by calindori :: removing kpeople breaks dependency 'kpeople' required by kpeoplesink :: removing kpeople breaks dependency 'kpeople' required by kpeoplevcard :: removing kpeople breaks dependency 'kpeople' required by plasma-mobile :: removing kpeople breaks dependency 'kpeople' required by plasma-phonebook :: removing kpeople breaks dependency 'kpeople' required by plasma-workspace MUST COMBINE WITH REMOVAL OF kcontacts pacman -R kcalendarcore checking dependencies... error: failed to prepare transaction (could not satisfy dependencies) :: removing kcalendarcore breaks dependency 'kcalendarcore' required by calindori <--REMOVE WITH kpeople, 1st :: removing kcalendarcore breaks dependency 'kcalendarcore' required by libkgapi :: removing kcalendarcore breaks dependency 'kcalendarcore' required by sink <--REMOVE WITH kcontacts, 2nd
With the information above, I attempted to remove kpeople.
I grew suspicious here. I found hard to believe that pacman considered plasma-mobile to be foreign
plasma-mobile
pacman -Qmq | grep plasma-mobile
gave no matches.
NOTA BENE: the above post makes no mention of this dependency when it says  to remove all foreign packages.
Clearly, such is not possible on my system.
Daunted, I continued for completeness.
pacman -R kpeople calindori kpeoplesink kpeoplevcard plasma-mobile plasma-phonebook plasma-workspace plasma-mobile-nm plasma-dialer plasma-pa plasma-wayland-session plasma-wayland-session powerdevil systemsettings checking dependencies... error: failed to prepare transaction (could not satisfy dependencies) :: removing kpeoplevcard breaks dependency 'kpeoplevcard' required by kdeconnect :: removing systemsettings breaks dependency 'systemsettings' required by plasma-desktop :: removing powerdevil breaks dependency 'powerdevil' required by plasma-desktop
No. Way.
I find myself in an absurd situation: an upgrade knocked out the modem.
How may I disentangle this Gordian Knot, and at least restore my modem,
ideally, complete the upgrade?
Partly (temporarily?) solved.
After executing
systemctl restart eg25-manager
ifconfig wwlan0
wwlan0: error fetching interface information: Device not found
ifconfig
I saw that both wlan0 and wwan0 disappeared.
rfkill unblock all
ifconfig wlan0 up
ifconfig
showed wlan0
I use eth0 and do not, at the moment, have wifi to test.
ifconfig wwan0 up
wwan0: ERROR while getting interface flags: No such device
reboot
Restored wwan0!
I can now make calls.
Also, activating wifi via GUI brought up wlan0.
I neither know if the system is truly fixed (as wifi shows neighborhood hotspots, but I have not tested it),
nor if what appears to be a fix will survive a reboot. (I need my phone for a good while before I can take a gamble).
Moreover, I do not understand /why/ what I did would restore the modem.
Any explanation/assistance would be welcome.
You want nmcli r wwan on, not nmcli r wifi on.
(12-05-2024, 12:11 AM)Kevin Kofler Wrote: You want nmcli r wwan on, not nmcli r wifi on.
Noted.
Thanks!
Exclamation No wIfI after Mobian update crakabeats 5 8,697 02-28-2026, 04:18 PM
Last Post: baptx
  Default password for KDE plasma pine phone Toni 0 8,507 09-14-2025, 06:35 PM
Last Post: Toni
  My new phone stopped working. gunnygee 3 4,949 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,430 12-06-2024, 02:42 AM
Last Post: tracyanne
  2G, 3G still is in phone. Piotr Bujakowski 5 6,984 09-19-2024, 03:49 AM
Last Post: jennybaso
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 9 11,630 06-30-2024, 12:26 AM
Last Post: Peter Gamma
  Looking for the "non-phone" OS wakyct 7 9,409 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 13,201 03-11-2024, 10:42 PM
Last Post: Emelia525
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 9,284 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 4,875 01-09-2024, 07:02 PM
Last Post: britelite
