2G, 3G still is in phone.
Hi.
Why that old not used 2G and 3G is still in phone?
Thanks for answers.
(07-30-2024, 10:01 AM)Piotr Bujakowski Wrote: Hi.
Thanks for answers.
i think question is poorly worded, you probably mean "why technical gsm/2g and umts/3g capability is in pinephone and pp pro even many networks has shutdown those networks?".
pinephone and pro uses eg25-g modem chip, which has gsm, umts and lte functionality. and lte in eg25-g support volte as well. eg25-g is intended for iot devices more than ordinary phones. but in other hand, many iot devices rely on lte and nr5g networks. software can disable those features, but capability is still there.
hint: use lte only or 4g only. some cases you have to use at commands.
Also, there are countries which still have working 2G and/or 3G networks, which may have better geographic coverage than 4G  (LTE).
In Austria, Magenta (T-Mobile) has shut down 3G (UMTS) on their network, but 2G (GSM) is still supported as a fallback for legacy phones not supporting 4G and for coverage. The other 2 physical network providers still support both 2G and 3G.
(07-30-2024, 12:18 PM)zetabeta Wrote: hint: use lte only or 4g only. some cases you have to use at commands.
for at commands. if gui is not available.
# shows a mode. AT+QCFG=“nwscanmode” # sets a mode. AT+QCFG=“nwscanmode”[,<scanmode>] <scanmode> Number format, network search mode 0 AUTO 1 GSM only 2 WCDMA only 3 LTE only
Just don't be surprised if you get worse network coverage in remote areas then. Forcing 4G/LTE only makes sense if your country has completely turned off both 2G and 3G networks (and even then, only as long as you are in your country, do not forget to turn 2G/3G back on for roaming abroad).
(08-05-2024, 11:32 AM)Kevin Kofler Wrote: Just don't be surprised if you get worse network coverage in remote areas then. Forcing 4G/LTE only makes sense if your country has completely turned off both 2G and 3G networks (and even then, only as long as you are in your country, do not forget to turn 2G/3G back on for roaming abroad). snow rider 3d
Mountainous and remote areas are the norm for poorer coverage, or even no coverage at all. So I agree with turning 2G/3G back on when roaming abroad.
  Default password for KDE plasma pine phone Toni 0 8,636 09-14-2025, 06:35 PM
Last Post: Toni
  My new phone stopped working. gunnygee 3 5,113 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 3,577 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 4,718 12-05-2024, 06:42 AM
Last Post: gilford
  Looking for the "non-phone" OS wakyct 7 9,683 03-14-2024, 03:51 AM
Last Post: MTXP
  Writing apps/programs for pine phone katesfb 7 13,466 03-11-2024, 10:42 PM
Last Post: Emelia525
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 5,014 01-09-2024, 07:02 PM
Last Post: britelite
  Can the Pine Phone be serviced and updated remotely? profileyourcity 3 5,324 10-02-2023, 05:19 PM
  UBports on pine phone? robb777 16 19,033 09-01-2023, 04:26 AM
Last Post: gregb49
  US Cell Phone Service Providers with prices and phone numbers - UPDATED jovval 0 3,922 07-01-2023, 01:25 AM
Last Post: jovval
