BalenaEtcher issues...
I have flashed multiple distros to my Pinephone many times.  However, now, Etcher is not picking up my Pinephone anymore.
The jumpdrive is 100% functioning (my Pinephone screen is visibly showing the jumpdrive graphic) but Etcher is still not showing the eMMc option (or whatever its called) in the list.
Any ideas on what is going on here?  Any solution suggestions?
Use a better tool. BalenaEtcher should not be used anyway, because it is privacy-invading spyware.
What to use instead depends on the operating system you use on your computer, which you have not specified:
  • On GNU/Linux, you have plenty of options. You can use dd from the CLI, or KDE ISO Image Writer, or GNOME Disks, etc.
  • On Windows, if you insist on using that, try Rawrite32, it's simple (no Electron etc.), BSD-licensed, and free of ads and spyware.
  • On macOS, if you insist on using that, you can use dd from the CLI, or possibly ports of the dd GUI frontends that you have on GNU/Linux.
I wonder why there are any people at all interested in the PinePhone who do not run GNU/Linux on their computer. If you are willing to run it even on your phone, where it is a totally niche option, surely you should have switched your computer to it years ago considering the state of desktop vs. mobile GNU/Linux.
(03-24-2025, 12:44 AM)Kevin Kofler Wrote: Use a better tool. BalenaEtcher should not be used anyway, because it is privacy-invading spyware.
in case of "dd" and balenaetcher, i recommend commading "sync" afterwards, preferebly as a root or using sudo. syncing may not happen in all cases.
(03-24-2025, 12:44 AM)Kevin Kofler Wrote: I wonder why there are any people at all interested in the PinePhone who do not run GNU/Linux on their computer. If you are willing to run it even on your phone, where it is a totally niche option, surely you should have switched your computer to it years ago considering the state of desktop vs. mobile GNU/Linux.
i may partially answer for this. i have used linux for years or is it decades at this point. but i'm also privacy advocate, which is additional argument for linux based operating systems. privacy wasn't my original reason why i started using linux.
windows 7 wasn't privacy nightmare. windows 10 started to have privacy issues and more in windows 11. if i take privacy as a point, windows is less worse than average android device. windows is still fixable, even it is difficult and tedious. that's why some people may use windows but seeking alternatives in smartphone world.
but linux distributions starting to be quite usable.
(03-24-2025, 09:11 AM)zetabeta Wrote: in case of "dd" and balenaetcher, i recommend commading "sync" afterwards, preferebly as a root or using sudo. syncing may not happen in all cases.
If you add the option "conv=fsync" to the dd command line syncing is done automatically before dd exits.
I have run Manjaro on a laptop for a few years.  Its a nice hobby but am simply not confident enough to daily drive it on my primary PC.  I would love to.  But I just am not there and thats really all there is to it.
And the Pinephone was just a nice little alt-comms hobby as well.  Not a daily driver what so ever.  At least not for me.
You have a good use case then for dual-boot or booting from a flash drive.
You can use whatever you like daily. But when it comes to doing things that work best in GNU/Linux, boot GNU/Linux.
:wq
But back to the point: when using rewrite32 to flash an OS to the Pinephone, is it as simple as just flashing the jumpdrive to the SSD, then plugging the phone up to my PC and then selecting (from the rewrite32) dropdown menu the phone?
If this is not the case, how does one flash using rewrite or win32? Having a hard time finding yt videos for options using anything other than Balenaetcher.
  ISO writing program: Tails warns against balenaEtcher walter1950 0 2,859 02-20-2025, 03:09 PM
Last Post: walter1950
  Multiple issues with the Pinephone MTXP 12 13,719 12-28-2023, 07:55 AM
Last Post: MTXP
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 6,586 05-10-2023, 03:31 AM
Last Post: fxc
  New Phone Opening Issues LuluFrance 5 7,164 03-15-2023, 05:33 AM
Last Post: anonymous
  PinePhone sound issues Chief 4 7,506 07-05-2022, 07:58 PM
Last Post: Chief
  postmarketOS fixed battery issues Deadladyofclowntown 1 4,320 06-23-2022, 02:44 PM
Last Post: zer0sig
  Pinephone 64 Issues of a new user US Notheast as of April 2022 scrwbigtek 9 14,223 05-03-2022, 04:18 PM
Last Post: scrwbigtek
  Pine Phone Pro issues gmastap 4 6,140 03-21-2022, 12:46 PM
Last Post: bcnaz
  u-boot multiboot issues m4xx3d0ut 0 3,585 02-24-2022, 05:11 PM
Last Post: m4xx3d0ut
  Safety issues with numeric login and sudo passord Line 5 9,619 07-05-2021, 12:17 PM
Last Post: zetabeta
