[Mobian] No return from locked phone
Hello there,
using the 20230129 installer image for Mobian, the installation on the eMMC went through fine, but everytime the phone locks itself or is manually locked with the power button, there is no coming back to the login screen. The phone stays dark, but is still running, because changing the volume with buttons still works.
Has anyone encountered the same problem or a solution for that behaviour?
Thanks in advance!
Cheers!
Solved by luck... It seems that auto brightness control must not be enabled at the moment.
  Experimental Mobian kernel patch for extended battery life teekay 15 17,015 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,016 10-20-2025, 07:01 AM
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 50 63,572 10-13-2025, 07:46 AM
Last Post: Habbytm
  Debian vs Mobian henrythemouse 3 3,808 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,146 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,176 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,210 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 2,090 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,867 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 1,989 11-07-2023, 10:01 AM
Last Post: mburns
