Cant get rockpro64 working
Hi everybody,
i have 2 RockPro64 and both behave strange.
I have a hdmi cable, keyboard and a ethernet cable connected.
The first rockpro64 i was trying to uses crashes a few secounds after the uboot screen. I tried Armbian and Debian and pretty much same behaviour.
After a few hours of trying the first board i was desperate and wondered if the board is simple broken and tryed the secound board i bought...
and it actually immediatly worked! I could boot the armbian version i previously was unable to boot with the first board! I created a user and logged in from remote via ssh. But now i see i cant use 'shutdown now' and then press the boot button or reset button. I need to reconnect the power for the board to reboot.
So i have 2 questions.
1. How can i fix the first board? It starts with the uboot screen boots linux but after a few secounds crashes. The screen goes idle and the power led is the only led on the board left on. (even the ethernet led is turned off)
2. What are the reset and boot buttons good for?
Are you sure that you have a reliable and working SD card? Do you have a proper PSU (min 3A that ha some weight to it)? I've had mixed results with various Armbian images in general but does the same occur if you try lets say Manjaro?
https://github.com/manjaro-arm/rockpro64.../tag/22.06
2. These are hardware buttons connected to the SoC afaik, reset not going to work the same as if you're using a x86 PC. I dont know offhand what the boot toggles.
(02-04-2023, 02:43 PM)brasilikum Wrote: ...
Mine work as per the wiki.
I am having the same issue, might be related to: https://wiki.pine64.org/wiki/ROCKPro64#N..._on_Debian
Not sure if this is your case since you are getting different results on two boards.
Here is a recording of the failing boot sequence: https://youtu.be/dENsLmDhq5Y
Manjaro worked great and now I am waiting for a Serial adapter for Debian installation.
  RockPro64 automatically run after power recovery - my solution g2t 1 1,789 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,472 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,802 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,541 11-26-2024, 11:08 AM
  power button not working Vista8720 0 3,436 05-07-2024, 11:26 PM
Last Post: Vista8720
  Installing Wifi drive for the RockPro64 John45595 0 4,752 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,266 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,931 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 14,001 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,222 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
