No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED
I think the title says it all. I tried to upgrade from the CLI, and when I tried to reboot, the phone won't. Furthermore: I tried connecting to my computer, then turning on the phone with the volume up button help down. The LED turns blue, indicating it's in mass storage mode, but the computer doesn't see it.
Also, I flashed the most recent installer, and pre-built image, to SD cards, but them in the phone, and neither are seen by the phone.
A semi-update: I learned from the tow-boot documentation that the Pinephone will not automatically load from an SD card unless you hold the volume button down while holding the power button. When I did this, I was able to boot from the installer SD. I'll leave this thread open in case someone has a specific solution to the issue of Mobian not booting. For my purposes, it was enough to re-install.
  activate vibration motor in bash script? vusra 0 992 07-18-2026, 03:47 AM
Last Post: vusra
  Disable vibrations 3x5co 9 16,799 01-03-2026, 12:26 PM
Last Post: baptx
  Full disk encryption with calamares: beware of last testing upgrade! mdk 3 5,997 02-21-2025, 07:25 AM
Last Post: dragonhospital
  Upgrade to Mobian (Trixie) Staging biketool 13 11,952 12-29-2024, 10:35 AM
  boot gets stuck shortly after disk decryption vortex 9 12,646 09-11-2024, 05:40 AM
Last Post: normangraves
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 11,366 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Command to test vibration motor? Zebulon Walton 3 6,157 11-12-2023, 08:45 PM
Last Post: zetabeta
  How to check if tow-boot is installed? jojuma 3 5,464 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 2,534 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 3,234 04-29-2023, 11:24 PM
Last Post: dcinoz
