Phone shuts down unexpectedly
Hey Everyone!
I hope you are well. I have a Pinephone Pro that I have been using for a daily driver the last few months. It has been running Manjaro Phosh stable edition. There was a massive update a few days ago though and since then the phone says that the battery is empty and shuts down when the battery indicator reaches about 70%. I tried reinstalling the Manjaro Phosh and using different batteries but nothing seems to work.
I haven't been able to find any mention of others having this issue but it is still fairly new to me. Not sure if I am missing some sort of config either. Has anyone come across this before? Any ideas how one might fix it?  Huh
I appreciate all help in this matter.
Regards,
Hobgoblin
Have you tried a different OS to see if the problem remains?
(12-18-2022, 11:22 AM)Fish Wrote: Have you tried a different OS to see if the problem remains?
I spent much of yesterday doing this. From what I can see the issue only seems to be with the stable version of Manjaro/Phosh. I tried Mobian, Majaro/Plasma, Arch and Manjaro/Phosh(Dev) and they all seem to be working fine. Thank you for your suggestion. I appreciate it.  Smile
I am glad to see it seems to be a software problem rather then a hardware problem Smile
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 50 64,053 10-13-2025, 07:46 AM
Last Post: Habbytm
  Guide to Suitable Phone State Borealid 19 27,253 09-18-2023, 07:00 AM
Last Post: robocone
  Phone Attitude(Device orientation) lurkadillian 2 3,698 06-22-2023, 08:12 PM
Last Post: lurkadillian
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 6,446 02-18-2023, 06:14 PM
Last Post: fxc
  [Mobian] No return from locked phone arno_nuehm 1 3,095 02-06-2023, 07:57 AM
Last Post: arno_nuehm
  Sound completely gone with Mobian in Phone Call configuration EwigeBlumenkraft 2 4,650 11-11-2022, 09:18 PM
Last Post: apink
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 2,630 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Outgoing audio in phone calls gone linuxfreedom 6 9,521 10-25-2022, 08:40 PM
Last Post: apink
  Phone wont turn on with any SD Card inserted Ausfaller 3 6,306 07-21-2022, 10:20 AM
Last Post: Ausfaller
  PPP Phone rings with constant vibrate - turn off vibrate henrythemouse 0 2,251 05-16-2022, 03:59 PM
Last Post: henrythemouse
