WiFi stopped on Pinebook Pro after update
After being gone for a month, I returned yesterday 23 Oct 2022 and thought 'let's update the Pinebook pro while I unpack'.  Running Manjaroo.  So I did, and after restart, WiFi no longer works.  Networks show "No available connections".  WiFi is on through the privacy switch (2 led blinks).  Any ideas how to fix?
Maybe this
https://forum.manjaro.org/t/wi-fi-stoppe...e/124956/2
(10-24-2022, 09:58 AM)tkudog Wrote: After being gone for a month, I returned yesterday 23 Oct 2022 and thought 'let's update the Pinebook pro while I unpack'.  Running Manjaroo.  So I did, and after restart, WiFi no longer works.  Networks show "No available connections".  WiFi is on through the privacy switch (2 led blinks).  Any ideas how to fix?
@tkudog I had the exact same thing happen.  Then I contacted support and was given limited info.
I was going to trash my pinebook (the trackpad is crummy and I don't want to spend more on it with a replacement part, etc.)
SO, I created a new account "foo" in order to delete my old account.  But the WiFI works in new account "foo".
Give it a try.
What is my guess?  The update messed up the WiFi settings on that one account, and I have no idea how to fix the settings.  (I am pretty technical and looked at all the settings - saw nothing amiss.)
Give it a try.
Sorry, the link in the first reply solved my problem:  "Try a cold boot.  Wifi and Bluetooth is really flaky when doing reboots/warmboots."
  Boot Order in Pinebook Pro food 14 19,297 1 hour ago
Last Post: noahclark
  Window Maker Live for Pinebook Pro vajak 9 6,585 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,272 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,695 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 13,537 07-04-2025, 07:46 AM
Last Post: remph
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 19,019 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,411 03-15-2025, 01:47 AM
Last Post: frank_philip
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,700 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,792 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,520 03-31-2024, 10:11 AM
Last Post: u974615
