Sound completely gone with Mobian in Phone Call configuration
Since a few weeks I have problems again with call audio in Mobian. I don't use my PPP for calls often so I cannot say when the problem started.
In the settings app the sound test works fine in the "Default" configuration but fails to play any sound when set to "Phone call".
I have flashed the current weekly image and had the same problem there. So no funny configs on my side I guess.
Also I tried restarting pulseaudio, pipewire etc. as was mentioned in other threads.
OK the latest version works now.
Should have tested actually calling someone. The test in the settings app fails but calling works.
That is good to hear.
Are you getting good quality sound?  And if so are you changing any settings to get it?  My sound quality is poor for sound going out from the phone.
I am using mobian, the latest release with an apt-get upgrade.
Question Call recording? Greendrake 8 19,919 03-01-2026, 11:40 AM
Last Post: baptx
  Experimental Mobian kernel patch for extended battery life teekay 15 17,018 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,017 10-20-2025, 07:01 AM
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 50 63,648 10-13-2025, 07:46 AM
Last Post: Habbytm
  Debian vs Mobian henrythemouse 3 3,808 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,146 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,176 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,216 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 2,091 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,868 11-18-2023, 08:21 AM
Last Post: crocspot
