Latest version Arch Plasma looks good.
Considering the issues with Phosh as of recent I have been testing the latest version of Arch Plasma and so far so good.
It still has the typical type Plasma bugs here and there but it looks promising.
Evolution and Libreoffice work well.
The graphic looks good too and is consistent.
The favourites screen still doesn't work as favourites disappear after reboot.
I have not tested calls as my main focus is PDA related.
TESTED: Arch Plasma, Arch Phosh , Manjaro Phosh, Manjaro Plasma
Fedora, Mobian, Postmarket Plasma, Postmarket Phosh, Kali, SXMO.
because i have been in this obsessive bug hunting, i have tested various plasma builds. plasma varies from os to os but starts to be usable in some distributions. fedora plasma seems to mostly work. my testing is quite superficial though.
So you have tried fedora plasma on Pinephone?
(10-21-2022, 09:28 PM)Chief Wrote: So you have tried fedora plasma on Pinephone?
i have tried it, but not for calls though. still plasma crashes in some cases.
I'm guessin' that the crashes are related to busted login? This is the case with Arch Plasma right now as I can expect a busted login whenever an HDMI is present.
If I use a BT mini keyboard it works perfectly with no HDMI. I can also use full size keyboard / mouse combo with no problems but as soon as HDMI is plugged the screen get messed up quick and then broken login occurs which usually requires a hard boot. On Arch plasma the screen rotation also works well. I see promise in
Arch Plasma. Perhaps I will download Fedora and give it a try on my other PP.
Edit: I think on my second phone I will try PureOS from Librem. It makes sense as Phosh is also developed by Librem. More to follow.
Latest observations on Arch Linux Plasma:
1. login breaks consistently for no apparent reason.
2. Calls and text appear to work but mobile data must be disabled for text to work.
3. Favourite app main panel does not hold favourite apps after logout or reboot.
4. onscreen keyboard can behave somewhat eratic at times, sometimes there and sometimes not.
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 10,107 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 4,094 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  Pinephone with KDE Plasma stuck at K logo after update Daniello 0 2,189 06-20-2024, 01:52 AM
Last Post: Daniello
  stuck between phosh and plasma aular 0 2,460 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 9,466 02-20-2024, 09:35 AM
Last Post: _radv_
  How to install arch with FDE user641 3 5,843 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 8,990 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 9,297 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 3,928 07-29-2023, 08:27 AM
Last Post: alpineduck
  Latest update broke my install user641 8 10,930 02-22-2023, 05:54 AM
Last Post: gregb49
