RockPro64 and Neon
Does it actually have neon support? I notice that it's not listed in /proc/cpuinfo. If it is supported does anyone have a good way to identify it in a configure script so I can actually build a project that supports neon?
Chris
Yes, in armv8 nomenclature this is "asimd" in /proc/cpuinfo for advanced simd extensions. Your compilers will automatically pick it up, as far as I know, as it's a base feature of Armv8.0-A I believe.
The gcc manual confirms my belief here by straight up saying +simd is default on armv8-a:
[Image: simd.png]
So nothing special is needed in any configure script, any build for aarch64 will use simd, though auto-vectorisation might not occur on lower optimisation levels.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(10-21-2022, 03:34 AM)CounterPillow Wrote: Yes, in armv8 nomenclature this is "asimd" in /proc/cpuinfo for advanced simd extensions. Your compilers will automatically pick it up, as far as I know, as it's a base feature of Armv8.0-A I believe.
Okay, I think I know what is going on then. I've been working with the optimized poly1305 MAC code from floodyberry (github.com/floodyberry/poly1305-opt) and the problem seems to be that it just is too old to properly support armv8. Specifically in that the assembly was only written for 32bit processors. I was getting turned around buy an error message that, for some reason, made me think that it was a problem with the neon code and not the armv6 assembly.
Thanks!
  RockPro64 automatically run after power recovery - my solution g2t 1 1,706 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,399 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,720 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,466 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,672 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,167 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,861 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 13,823 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,156 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 6,537 04-06-2023, 02:46 PM
