Pinephone: OpenGL support?
Does either the Pinephone or Pinephone Pro offer conventional OpenGL support, or are they limited to OpenGL ES?
And is there any hardware acceleration?
Thanks.
The OpenGL vs OpenGL ES comparison is a bit tricky. In general, ES is a subset of a given version of "full" OpenGL. However, if a program expecting full GL doesn't use any of the missing features (how many features are missing also depends), then there's no functional difference.
The GPU in the original PinePhone can do ES 2.0, which is pretty close to full OpenGL 2.1. The PinePhone Pro can do ES 3.1, which can also run full 3.1 applications most of the time. There's also work towards 3.2 support as well.
"Hardware acceleration" is a broad term, so you would have to specify. If you mean 3D acceleration or video encode/decode, the answer is yes.
Well, it depends on whether you want hardware acceleration or not.
If you want hardware acceleration, then refer to what fire219 said.
If you don't need hardware acceleration, you can get almost everything Mesa supports for OpenGL by using the zink driver (set the environmental variable MESA_LOADER_DRIVER_OVERRIDE=zink) which does OpenGL over vulkan. Now, the original PinePhone does not have accelerated vulkan at all (no idea on the PinePhone Pro), so it does vulkan using the lavapipe driver, which is a pure software implementation of vulkan and therefore has no acceleration. This works quite well, just is slow is all. Very useful for some programs.
  asterisk or FreePBX on pinephone? vanja 0 446 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 23,162 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 6,965 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 233,084 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 220,656 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 981 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,187 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 66,168 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 5,517 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 74,738 07-26-2024, 10:35 PM
