postmarketOS/Alpine edge image for the Pinebook Pro
#71
(06-17-2021, 05:02 PM)spin stozi Wrote: Might as well not offer a sway version, just let us install from bare version, so we can make sure a terminal works
I'm afraid I have to agree with @stozi here. The state of the sway version after first boot was pretty frustrating for me as well. I've been around Linux long enough to know that CTRL+ALT+Fx will let me escape the auto-login loop and repair the terminal issue from a console shell, but how many users will figure that out on their own? And even I ended up using the bare version in the end. I was really surprised with sway version of Manjaro though, their sway spin is really nice and polished. To be honest, that's where I realized that I'd like to use sway as my wm of choice. I'd rather use Alpine based OS though. I'd really like to help make sway spin of PostmarketOS better, but I'm not sure where to start. Is all the configuration (for things @stozi mentioned) supposed to be done (or even possible to do) through .post-install inside https://gitlab.com/postmarketOS/pmaports...os-ui-sway?
id like to see a manjaro patched pbp kernel in the repo's not sure whats in it now but if i use wireless, panfrost and brcmfmac crash like clockwork double fast if using sdcard aswell, using a wireless dongle has spared me constant kernel crashes so im gonna blame the broadcom driver
just tried PmOS Plasma again, didn't accept root password (147147 or the one I set during install) nor would it connect to my wifi. would love it if it worked
I've tried a few distros on the Pinebook Pro in the year (?) or so that I've had it, and I have to say that postmarketOS has easily been the best experience. I can't remember if I used the basic image or the sway one, but either way I've had absolutely no issues with postmarketOS. Easy install, easy FDE setup, everything just seems to work. Can recommend (at least the sway version).
I can't get audio to work in the sway edition. After installing pavucontrol I can see that audio is working in Firefox/Falkon but no sound from the speakers...
Gesendet von meinem RMX3085 mit Tapatalk
  Boot Order in Pinebook Pro food 15 19,737 Yesterday, 01:09 AM
Last Post: NorrisFByrd
  Window Maker Live for Pinebook Pro vajak 9 6,700 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,339 08-09-2025, 06:53 AM
Last Post: Sb2024
  What's a good image to use now? [tutorial help as well] frank_philip 40 33,261 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 18,515 03-10-2025, 01:55 PM
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,810 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,859 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,635 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,970 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,466 12-13-2023, 07:22 PM
Last Post: trillobite
