New issue with phone calls
(08-09-2022, 03:21 PM)alaraajavamma Wrote: If it helps there is no such issue with PMOS stable and PP Beta.
I have one Pinephone for testing/developing and I am trying Manjaro Phosh currently - it feels much "snappier" when you are using it but all regular phone functionalities are (much) less stable.
Since you told your experience with PMOS, I tryed it on my PP and effectively the sound worked perfectly. But I started installing apps and later it fails again with the same thing (changing to earpiece and hearing nothing on calls...) so I'm starting to think that the problem is on the installation of any app (maybe audiotube?) that makes dysfunction with the sound configuration. It happens to me the same on the phosh system of Manjaro.
Looking quickly I don't know why audiotube would broke call audio.
If you lose audio during call look at this:
"Receiving second call while on call" issue (and workaround) what you might find helpful:
https://gitlab.gnome.org/GNOME/calls/-/issues/428
If you have awesome Biktorjgs firmware installed you can send SMS "callwait auto hangup" or "callwait auto ignore" to +223344556677
Or is the call audio problem there at the beginning of call?
Btw.
There is also another issue regarding call audio:
If there is call which no one answers (incoming or outgoing) the audio stays at "Make a phone call" aka earpiece as long as you switch it manually or make/receive call which is answered and the audio returns to speaker when the call ends.
This makes harder to notice if someone tries to call you because ringtone is played "Make a phone call" aka earpiece mode Smile
This is fixed in Calls 43 but that is not released yet so I suggest to suffer and wait Smile
And please see this also:
https://gitlab.freedesktop.org/pipewire/...te_1236739
I played with Manjaro Phosh today and have to say that there are issues with call audio Smile
(08-14-2022, 12:40 PM)alaraajavamma Wrote: And please see this also:
Yes, this is it. The issue is when I end a phonecall, it switches on the "earpiece" function on the "make a phone call" configuration. But it does the same thing when I click on "play hifi quality music" and return again to "make a phone call": I notice that it is on "earpiece" again.
Well, we have nothing to do but wait till this is solved.
Thanks so much friend.
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,863 07-03-2024, 08:38 PM
  debugging issue realted to iso image wth extra data eror penguins_rule 3 5,275 06-18-2024, 01:18 AM
Last Post: waderatke
  systemic issue pinephone penguins_rule 3 4,873 04-02-2024, 11:52 AM
  New phone, KDE desktop settings reset on reboot zzb0 2 6,260 10-15-2023, 10:19 PM
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 3,004 09-24-2023, 05:18 PM
Last Post: nbh
  Calls/Texts and External Monitor gregb49 0 3,144 06-30-2023, 11:38 AM
Last Post: gregb49
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 16,454 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  new PinePhone upgrade issue WhiteHexagon 5 7,637 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Internal Microphone issue during calls Viktor 6 8,503 03-31-2023, 08:58 AM
Last Post: Viktor
  Firefox issue with latest update Barugon 6 8,206 01-28-2023, 01:29 AM
Last Post: alaraajavamma
