Pinephone craches after each call
Pinephone craches after each call and needs to be restarted
Hmm, can't reproduce it here. Are you at the latest version?
Sometimes the calling window stays fullscreen and hides window control buttons at the bottom of screen, so you can't close the window. In this case workaround was to open the Phone Settings window - then the window control buttons reappeared.
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
This happens almost every time a call is received or after a call is made. After a received call in the sound settings you might notice "dummy output". in most cases the phone must be rebooted. Other times you might see different settings such as default but the mic no longer responds. In that case you can log out and then log back in. The mic may work again. Saves a bit of time.
Arch Linux Phosh.
  New PinePhone user issues greenpineuser 8 7,948 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 19,084 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,826 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 4,558 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 4,806 04-02-2024, 11:52 AM
  new PinePhone upgrade issue WhiteHexagon 5 7,530 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Can't add micro SD card to Pinephone thorensjubilee 7 8,675 02-27-2023, 10:21 AM
Last Post: mikehenson
  Pinephone Freeze kmsgli 14 18,958 02-04-2023, 08:35 PM
Last Post: Westslope
  Unable to hear caller or speak after answering a call danimations 5 8,670 11-01-2022, 02:06 PM
Last Post: X0X0X0X0X0
  Weird call... Eugo 3 5,735 09-15-2022, 11:20 PM
Last Post: Eugo
