Rock64 Rev3 doesn't boot and leds blinking fast
I just purchased a 4gb Rock64 Rev3 model and i'm struggling in getting any image to boot properly, i tried latest Armbian, mrfixit and ayufan's image. Whenever i plug my power supply (5v 4A) the white, red and ethernet led starts blinking very fast while the green blink slowly. If i plug in and out my power supply it will eventualy boot, but never from the first time. Maybe my board is defective? Anyone else has this issue?
(08-11-2019, 07:57 PM)dishins Wrote: Hello,
Sounds like a power issue, the green LED should be on solid when plugged in regardless if the board is booted or shutdown as it's hardwired to the power socket..
I'm not sure, my Rock64 1gb Rev1 board boots fine with the same power supply, also, if i plug and replug several times it will eventually boot. Is the Rev3 more power hungry. Actually the green led behaves more like a DIM than blink i should say.
Did You solve? I have the same problem.
Did You solve?  I have a  similar problem.  I use the Ubutu system ,and the board is not start normally,  and all LED is on,  includthe red one.
Did you try Armbian
no, I purchased another one ,which is work well .
  rAudio for Rock64 V2/Pine A64+ shinzuka 13 2,572 07-28-2026, 08:08 PM
  DietPi OS for ROCK64 MichaIng 43 89,384 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,450 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,433 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,485 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,475 11-03-2025, 09:25 AM
Last Post: darkfader
  PXE Boot example? lewis 7 17,240 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  can rock64 4gb ram run entirely on free software? heocb 1 3,484 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,665 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  How to boot an older, working kernel bits 0 2,729 11-01-2024, 04:43 PM
Last Post: bits
