Chatty can no longer start since the last update
Sad
Hello
I cannot read my SMS, Chatty doesn't open anymore since the last update (libpurple?). When I naively tried to run it in command line by entering "chatty", it complained about a missing shared library libjabber.so.0. What can I do to fix it? Where should I look for error logs?
(05-21-2022, 12:18 PM)anonymous Wrote: Hello
same error here...
It looks like it will be fixed in the next version of chatty 0.6.4:
https://bugs.debian.org/cgi-bin/bugrepor...ug=1011166
same error here...
Thank you for your reply. "ln -s" might help in the meantime but maybe I should just wait for a clean fix.
I tried building Chatty 0.6.4 from here https://source.puri.sm/Librem5/chatty/-/tree/v0.6.4
but I had an error on the meson build stage (meson.build:113:0: ERROR: Subproject exists but has no meson.build file)
Try at your own risk, I forced installation of 0.6.4-1 from https://packages.debian.org/sid/arm64/chatty/download
using
sudo apt-get install -f ./chatty_0.6.4-1_arm64.deb
and that worked for me. Hopefully my build attempts did not affect it and would work for others. I have not tested it but it runs i.e. launches as per normal.
Hopefully a fix will be available via the usual Mobian updates.
I entered this in command line:
wget http://ftp.de.debian.org/debian/pool/mai..._arm64.deb
sudo dpkg -i chatty_0.6.4-1_arm64.deb
Then, I rebooted my pinephone (mandatory, otherwise you just get a blank Chatty) and it worked Smile
dcinoz, as you can see in the bug report, the fix will be available in about 4 days for others.
When building from source, I received an error for a missing libpurple0.so file. I had libpurple0 in my /var/cache/archives still so it worked after I downgraded by running:
dpkg -i /var/cache/apt/archives/libpurple0_2.14.8-1_arm64.deb
I did the same thing with pidgin-data prior to that, but I don't think it fixed anything.
(05-22-2022, 05:24 AM)anonymous Wrote: I entered this in command line:
That worked for me, thank you!
I hit the same problem and was able to fix it without installing anything:
$ LD_LIBRARY_PATH=/usr/lib/aarch64-linux-gnu/purple-2 chatty
It's the advice provided here, except replacing "x86_64" with "aarch64" in the path: https://bugs.debian.org/cgi-bin/bugrepor...ug=1011166
By the way, is there any way to know if apt-upgrading will break our phones ahead of time? I would have been happy to just not upgrade until the fix is up.
(05-25-2022, 07:33 PM)amindfv Wrote: By the way, is there any way to know if apt-upgrading will break our phones ahead of time? I would have been happy to just not upgrade until the fix is up.
Not that I know of other than holding off on potentially problematical updates and keeping an eye out here for reports of problems.
I do full image backups of my eMMC periodically so if something serious breaks I can get the phone back to a working state. I also keep a "known to work" sd card handy just in case.
Received update yesterday that included chatty. Chatty now launches successfully and I can send/receive texts again. The new chatty version has new features that seem quite useful.
I appreciate so much the work that all of the developers put into advancing this functionality of the pinephone. I will continue to support by using the device and software that I enjoy using. I will try to find other ways to support as best as I can.
  New Install, apps start but don't show up on screen?! RT3 2 225 07-18-2025, 07:56 PM
  how to update mobian over tor vusra 14 12,918 12-04-2024, 07:01 PM
Last Post: vusra
  Chatty Matrix Decryption Key jojuma 2 1,968 02-26-2024, 12:48 PM
  Errors when start the system kubussz 2 2,162 11-21-2023, 11:07 AM
Last Post: kubussz
  Jabber with chatty user641 2 2,411 11-12-2023, 02:10 AM
Last Post: user641
  Auto start application on Phosh login Zebulon Walton 8 7,388 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Chatty does not work after suspend mode user641 4 4,023 07-18-2023, 10:43 AM
  Wifi doesn't work after update nickolas 2 2,561 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 2,815 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 9,560 02-26-2023, 01:01 PM
Last Post: anonymous
