Latest firmware for PinePhone modem!
(05-03-2022, 06:47 PM)mark1250 Wrote:
(05-03-2022, 05:02 PM)robthebold Wrote:
(04-02-2022, 03:54 AM)Juergen Wrote: I use the open modem firmware from Biktor (0.61) and just tested "mobian-pinephone-phosh-20220327.img.gz".
At incoming calls the phone does not ring reliably.
In PMOS (edge) it works perfectly.
(Braveheart Edition 1.1.)
Not quite as good a result here.  Sad
I've got the Biktor modem firmware and PMOS edge, too, but still don't have reliable incoming call service. Playing around with other distros, too, but so far no luck.  USA, AT&T MVNO. And of course the problem is I don't know if I'm not getting calls because no one's calling or I'm not getting calls because the modem has decided to take a nap.  At least until my wife comes in and demands to know why my nerd phone isn't working and she gets my voicemail. Domestic tranquility may require me to get a flip phone or something.  Angry (Still better than Android, though.)
If anyone's got any good suggestions as to how to periodically poke the modem with a pointy stick so it doesn't doze off, I'm all ears.
Did you follow Biktorgj' recommendation about the udev rule? Here is a link for the OG Pinephone.
Basically you need to edit /usr/lib/udev/rules.d/80-modem-eg25.rules. Change "auto" to "on" in the 1st line and reboot.
Nope. I completely missed that (or at least misread it). Good excuse to finally install nano. I've edited and rebooted and will see what happens
OK. Been running with the changes for a couple days now. I don't think the modem bails on me as often, but I've caught it at least once. Usually the cell "bars" will disappear when this happens, but there have been times I missed calls when everything appeared fine and I'd only notice when the phone wouldn't ring but a while later a (possibly delayed) text from the service provider showed up that I think was meant to notify the phone about a visual voice mail. (It wasn't formatted for human readability.)
I wonder if there's anything I can do script-wise that can periodically check on cellular connectivity and alert me that I should reboot the phone. I'll post if I find anything useful on that.
What's the deal with 30.004.30.004? The release notes make it look like just a newer version of the ADSP firmware, but why is the version number so much higher?
(12-08-2020, 02:03 AM)dcinoz Wrote: FYI 5 additional VoLTE profiles (in bold):
Edit: $mmcli --list-modems | grep -oP "(?<=Modem/)[0-9]+" to get correct modem 'number'
$mmcli -m 0 --command='AT+QMBNCFG="list"' (modem number may not be '0')
Edit: As per https://forum.pine64.org/showthread.php?...1#pid85971 from fdlamotte above command can be simplified using -m any instead of a number as there is only one modem in the Pinephone:
mmcli -m any --command=.....
Response:
+QMBNCFG: "List",0,0,0,"ROW_Generic_3GPP",0x05010820,201905141
+QMBNCFG: "List",1,0,0,"VoLTE-ATT",0x0501033C,202004261
+QMBNCFG: "List",2,0,0,"hVoLTE-Verizon",0x05010141,202004091
+QMBNCFG: "List",6,0,0,"Commercial-SBM",0x05011C18,202004211
+QMBNCFG: "List",8,0,0,"Reliance_OpnMkt",0x05011B38,202003251
+QMBNCFG: "List",9,0,0,"TF_Germany_VoLTE",0x05010C1B,202004151
+QMBNCFG: "List",11,0,0,"Volte_OpenMkt-Commercial-CMCC",0x05012071,202004161
+QMBNCFG: "List",12,0,0,"OpenMkt-Commercial-CT",0x05011322,202001171
+QMBNCFG: "List",13,0,0,"OpenMkt-Commercial-CU",0x05011505,202001171
+QMBNCFG: "List",14,1,1,"Telstra-Commercial_VoLTE",0x0580079E,202006101
+QMBNCFG: "List",15,0,0,"Commercial-KDDI",0x0501071D,202004041
+QMBNCFG: "List",16,0,0,"Commercial-DCM",0x05010D17,202006101
+QMBNCFG: "List",17,0,0,"Commercial-SKT_VoLTE",0x05012724,201907221
+QMBNCFG: "List",18,0,0,"Commercial-KT",0x05012C0D,202005071
Note 1,1 indicates Telstra for me (though not currently available to Telstra MVNOs so can't test).
The following AT commands could be of interest to you, not sure what defaults are.
# SelectVoLTE profile
AT+QMBNCFG="Select","Telstra-Commercial_VoLTE" (use relevant name for you)
# Deactivate active profile
AT+QMBNCFG="Deactivate"
# Configure MBN Automatic Selection Function
# Return current configuration
AT+QMBNCFG="AutoSel"
response: '+QMBNCFG: "Autosel",1' (enabled)
response: '+QMBNCFG: "Autosel",1' (disabled)
#Set to autosel
AT+QMBNCFG="AutoSel",<enable>
where <enable> 0 disable, 1 enable
# Enable calling over ip (VoLTE)
AT+QCFG="ims",1
# Check ims status
AT+QCFG="ims"
Response:
+QCFG: "ims",<value>,<volte_state>
<value>              IMS function configuration parameter
                0        The NV about IMS can be set by the configuration of the MBN file
                1        Enable IMS function
                2        Disable IMS function
<volte_state>      VoLTE state
                0        VoLTE is not ready
                1        VoLTE is ready
Edit: Don't believe this is needed as it is Set Phone Functionality command (might be needed to enable settings changes)
# Reboot the modem to apply the settings # THIS IS WRONG
AT+CFUN=1,1 # THIS SETS FULL PHONE FUNCTIONALITY AND RESETS THE ME
AT+CFUN=1,0 # this sets full (default) functionality (1) and does not reset the ME (0)
# Set Phone Functionality
AT+CFUN=<fun>[,<rst>]
<fun>          0      Minimum functionality
                   1      Full functionality (Default)
                   4      Disable the ME from both transmitting and receiving RF signals
<rst>          0      Do not reset the ME before setting it to <fun> functionality level.
                          This is the default setting when <rst> is not given.
                   1     Reset the ME. The device is fully functional after the reset.
                          This value is available only for <fun>=1.
Response:
OK
If there is an error related to ME functionality, response:
+CME ERROR: <err>
# Check Phone Functionality
AT+CFUN?
Response:
+CFUN: <fun>
End edit.
Write down your actual configuration values / settings before changing anything and don't blame me - I don't believe you can break anything permanently but things could stop working until you revert back to your current configuration, you have been warned.
Google is your friend for Quectel PDFs though I couldn't find one for the EG25-G.
Be aware of the m modem number increasing as modem sleeps / wakes up.
Be aware that " is used in the commands.
AT commands can also be sent using minicom or screen for example using /dev/ttyUSB2 (Mobian, not sure on other OSes).
I've tried uploading and 'Adding' MBN files (new profiles) from a Xiaomi Android phone but it failed (Optus and Vodafone), presumably due to not being signed correctly. I wonder what will happen in terms of future support / updates from Quectel.
Hey, I know this is a long shot since I don't even have a Pinephone. But what I do have is a device that uses the same underlying modem. Is there any chance someone could provide me the Volte-ATT.mbn file so I can add AT&T VoLTE calling support to my device? I tried extracting it from the firmware images myself, but I cannot for the life of me figure out where the carrier configuration files are being stored. If they're in there, they're either in one of the .img files I can't get to extract, or they're named differently once actually flashed somehow. I'm just lost and tired, and figured maybe someone here already has a copy of the file I need anyways. I suppose a dump of all the carrier-specific MBNs might be useful for recovery purposes anyways for someone, so it couldn't hurt to have them uploaded somewhere if someone can get them or already has them. Hope it's not too much trouble. Thanks.
(07-07-2022, 04:24 PM)simcommbn Wrote: Hey, I know this is a long shot since I don't even have a Pinephone. But what I do have is a device that uses the same underlying modem. Is there any chance someone could provide me the Volte-ATT.mbn file so I can add AT&T VoLTE calling support to my device? I tried extracting it from the firmware images myself, but I cannot for the life of me figure out where the carrier configuration files are being stored. If they're in there, they're either in one of the .img files I can't get to extract, or they're named differently once actually flashed somehow. I'm just lost and tired, and figured maybe someone here already has a copy of the file I need anyways. I suppose a dump of all the carrier-specific MBNs might be useful for recovery purposes anyways for someone, so it couldn't hurt to have them uploaded somewhere if someone can get them or already has them. Hope it's not too much trouble. Thanks.
you could use https://github.com/jrspruitt/ubi_reader or similar to unpack files.
however, i did not find the files you were looking for. because of possible copyright reason, i don't provide links to the files.
(05-06-2022, 01:29 PM)robthebold Wrote: I wonder if there's anything I can do script-wise that can periodically check on cellular connectivity and alert me that I should reboot the phone. I'll post if I find anything useful on that.
Sorry for reviving a dead thread, but I could not see your profile to pm you and I saw that your account seems to still be active.
Here is a script that you can put in either your user or the root's crontab depending on if you want your phone to reboot automatically upon a modem crash.
Here is the ugly script that I use to do that and I adapted it with notify-send if you would rather have notifications instead of a cold reboot.
Notes
- this assumes a non systemd distro (I am not familiar with systemd) (iirc, you use postmarketos)
- It is not php code, it is only the text editor that puts that title
Desktop notification on modem crash (non automatic reboot)
0. Create the directory `/opt/sbin/`
# mkdir -p /otp/sbin
1. Put this script in `/opt/sbin/modem-check`
PHP Code:
#!/bin/sh
export LANG="en_US.UTF-8"
MODEM_STATE=`nmcli device|grep cdc-wdm0|head -n1|xargs|cut -f3 -d' '`
MODEM_STATE_CONNECTED="connected"
if [ "$MODEM_STATE" != "$MODEM_STATE_CONNECTED" ]; then
        notify
-send "Modem crashed. Reboot in order to bring it back online."
fi
2.1 Open the crontab for your user (not root, not through sudo)
PHP Code:
$ crontab -e
2.2 Add the following line at the bottom of your crontab
PHP Code:
*/30    *      *      *      *      /opt/sbin/modem-check
2.3 Save it and quit
3. Enable crond
PHP Code:
# rc-update add crond
4. Start crontab monitoring without rebooting
PHP Code:
# rc-service crond start
Automatic reboot on modem crash
If you want to reboot your phone automatically (Be careful, as you could experience data loss if you are using the phone while the phone reboots)
PHP Code:
# mkdir /otp/sbin
1. Put the script code in `/opt/sbin/modem-check`
PHP Code:
#!/bin/sh
LOG="/var/log/modem-check-crash"
echo "`date '+%Y-%m-%d %T'`: modem crashed, rebooting." >> "$LOG"
        reboot
fi
2.1 Open the crontab for the root user
PHP Code:
# crontab -e
2.2 Add the following line at the bottom of the root's crontab
PHP Code:
3. Enable crond
PHP Code:
PHP Code:
It is surprising Quectel does not have public download links on their official website but after contacting Quectel tech support by email, they sent me a SharePoint download link for the latest modem firmware on the PinePhone, which is EG25GGBR07A08M2G_A0.303.A0.303 released on 2025-11-11.
I noticed that on new firmware, the release notes says we cannot downgrade below version EG25GGBR07A08M2G_30.200.30.200, "otherwise the module will not be able to work normally".
Did PinePhone users like @dchang0 (https://forum.pine64.org/showthread.php?...#pid123728) who upgraded to a version that don't support downgrades have any issue (e.g. with echo cancellation, call recording or GPS)? Would you recommend it and is there an advantage?
I also asked someone with the same firmware here:
https://github.com/Biktorgj/quectel_eg25.../issues/28
  Solutions to modem / connection problems Anna 4 7,482 09-13-2026, 07:52 AM
Last Post: idice
  asterisk or FreePBX on pinephone? vanja 0 924 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 25,656 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 8,167 06-04-2026, 02:10 AM
Last Post: merom
  Fedora + Phosh for PinePhone njha 77 234,662 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,422 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,759 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 72,234 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,219 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 81,746 07-26-2024, 10:35 PM
