Modem unreliable on the PPP with Mobian
I am using my Pinephone Pro EE since monday as a daily driver. Works good so far but since yesterday the modem began having hiccups.
Sometimes it shows no reception or the bar symbol is crossed out completely.
With mmcli I can see the modem in the first case but in the second it is not found.
I tried various combinations of mmcli scan and disable/enable with no result. Only restarting the phone works most of the time.
However when I restart the phone some settings (display zoom, input voltage from keyboard etc.) are gone.
Is there a reliable way to use modem manager to restore the connection?
What modem firmware are you running? Biktorg version with advised parameters works fine for me.
(03-17-2022, 01:58 AM)dukla2000 Wrote: What modem firmware are you running? Biktorg version with advised parameters works fine for me.
I am still on the stock firmware.
  Experimental Mobian kernel patch for extended battery life teekay 15 17,021 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,017 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 3,809 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,146 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,176 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,216 10-28-2024, 10:46 AM
Last Post: Jite
  DeviceNotReady After flashing modem firmware nekonosuke 4 6,666 02-13-2024, 11:36 PM
Last Post: nekonosuke
  Disable the GDM service in Mobian. mburns 0 2,092 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 3,868 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 1,991 11-07-2023, 10:01 AM
Last Post: mburns
