TV64, a Android TV Experince 0.2
#21
Yes, DroidMote worked perfectly. Thank you!
Now, from what I have experienced so far, this system is working exactly as I had hoped. Except for one thing, which I find very strange:
I have some albums with 5.1 channels encoded to DTS or AC3 file formats, one file per album, with a cue sheet to get track titles and timings. In Kodi I have set "passthrough" for DTS and AC3 files. The signal is transferred to the receiver through S/PDIF, extracted from the HDMI out. So I would think that Kodi does nothing except passing the data directly to the receiver, which does the decoding. The problem is that the music is played back at the wrong speed/pitch, it is too slow. And then the album is cut off too early. DTS files are encoded to 48000 hz, but it seems like Kodi thinks it is 44100 hz. I do get 5.1 channels. There is no problem with CDs ripped at 44100 hz. I have a Raspberry Pi sitting next to it, and the Pi is playing back the files perfectly. So this problem must be specific to either the board or Kodi for Android. Has anyone else experienced this?
#22
I was able to get this running on my 1GB Pine, but it is very laggy. My Pine got very hot and powered off. This happened three or four times before I realized that was getting hot and probably shutting down because of that. What could be the issue here?
I am looking to make a media center that can access Netflix, uTorrent, Plex, etc. so it can pull movies and TV from my server as well as online, from a remote location.
#23
(05-27-2016, 12:02 AM)trondis23 Wrote: Yes, DroidMote worked perfectly. Thank you!
Passthrough doesn't work as it should... the sound fails a lot when playing files in Kodi, this board is far from being able to do anything right now... it's just for experimenting stuff.
#24
Yesterday Google Play uninstalled itself after displaying a message that it was incompatible with my device. Before that happened I installed some programs from my PC.
#25
(05-30-2016, 04:41 AM)trondis23 Wrote: Yesterday Google Play uninstalled itself after displaying a message that it was incompatible with my device. Before that happened I installed some programs from my PC.
This software is in alpha state. Better stick with your RPi for now.
#26
Looks like this version doesnt support ethernet connection. at least i didnt have internet via ethernet and there are no settings for ethernet.
any ideas?
#27
(06-01-2016, 01:26 PM)metaplita Wrote: Looks like this version doesnt support ethernet connection. at least i didnt have internet via ethernet and there are no settings for ethernet.
any ideas?
Worked for me just fine. Maybe try a reinstall. Only issue I have is it overheats
Sent from my SAMSUNG-SM-G925A using Tapatalk
#28
Same here. no ethernet at all under settings. I have tried both the Android 5.1.1 and Android TV images and same result on either.
Also can't get any of my wifi adapters to work.
#29
Ditto. Ethernet not working at all. Using 2GB board.
#30
Hi.
Just install and reinstall this DD image on my Pine64(2GB).
Twice i have seen purple screen and mouse point.
After few attempts of rebooting, i understand, that without Ethernet cable i have working Android. But if i connect Ethernet cable, the screen become purple(or blue) and i can't do anything.
That's the problem?
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,658 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 579,444 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 47,258 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 30,204 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,902 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,274 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,861 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,278 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 391,048 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,007 02-26-2019, 11:58 AM
Last Post: Twistedx
