Mobile case wanted - with wireless charging!
Hello everybody,
I want to get a case for my pine phone and I'm not sure where to get it. I want to get something like this: https://www.amazon.co.uk/Hianjoo-Compati...C80&sr=1-9
My pine phone has the replacement wireless charging mode on the back which makes for a deeper phone. What should I go for? Can anybody help, please? I'm in the UK.
Chris
I just bought Pine64's case. https://pine64.com/product/pinephone-sof...tive-case/
They also sell a Qi/wireless charging case that doesn't make the phone thick. https://pine64.com/product/pinephone-pin...d-on-case/
Both are _cheap_ IMO. Last Android case I bought was $25USD. Plus buying from Pine64 supports the community. Jeff Bezos doesn't need any more support.
Jp
PPv1.2a running PMOS ... almost a daily driver!
Yes, but I want a soft, protective case, and Pine phone don't make them, otherwise I'd buy them!
Chris
(03-10-2022, 08:25 AM)thorensjubilee Wrote: Hello,
Chris
If you use a case from a Galaxy Xcover Pro the dimensions are very close and the buttons are close as well. If its a Folio style case that holds just the corners it will work you will just have to cut a spot for the camera.
Here is a hard case I bought for a xcover pro and drilled holes for the camera
https://forum.pine64.org/showthread.php?tid=16171
I am in the process of ordering an otter-box case for the xcover pro to see if i can modify it to fit since it looks like a more sturdy case.
Chris
My case _is_ soft.
You probably confused the Qi/wireless back cover with the protective case.  They're 2 different products.
  more mobile linux on reddit(thank Goog for signed APKs) biketool 2 9,287 09-08-2025, 12:03 PM
  beta release of a Linux mobile app strength training app coryholl 1 3,312 08-29-2025, 06:06 PM
Last Post: coryholl
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 14 22,896 07-18-2025, 04:24 PM
Last Post: dchang0
  Public Mobile (Canada): failure to configure VoLTE digdis 6 4,628 07-14-2025, 04:17 PM
Last Post: digdis
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 2,805 04-02-2024, 11:50 AM
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 8,443 12-13-2023, 01:24 AM
Last Post: oldschool
  New Zealand network providers mobile data Linux2thabone 3 6,452 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 8,965 06-30-2023, 11:39 PM
Last Post: ionmich
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 3,043 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cannot call at several mobile phones Gon 3 4,742 05-04-2023, 05:18 AM
Last Post: Gon
