Armbian on Quartz64
#21
(11-22-2021, 01:25 AM)balbes150 Wrote: If you (or Pine64 or someone else) provide me with the necessary hardware (samples), I am ready to add CSC level support. If you want to get the "supported device" level, Pine64 needs to contact the Armbian developer community and discuss all the nuances of this work.  Smile
PS This applies not only to the Quartz64, but also to other models.
Please PM me your shipping address (including email and phone number for shipping purpose) and I will provide the necessary Quartz64 hardware.
Quote:Here you go:
Tnx
Interestingly, I see in the log output that quartz64 (as well as Station M2 rk3566) normally detects memory at a frequency of 1560, although by default the settings for 1056 are usually used for rk3566. If this is the case, in theory it should give better memory performance. Do you have everything working without problems, there are no bugs in the work from increasing the frequency?
Quote:Please PM me your shipping address (including email and phone number for shipping purpose) and I will provide the necessary Quartz64 hardware.
Tnx
I wrote to you in PM
Glad they send you one Smile
you see already the first overclock option Smile
only real diffrence i see that firefly has dmc doing diffrent as rockchip or raxda in legacy kernel
your legacy 5.10 firefly port , did compile a little more nice as the rockchip one , i only dont get hdmi out working in 5.10
and i noticed that your 35xx-next-211 looks similar to firefly 206 and your 206 is way diffrent .
(02-01-2022, 01:31 PM)shaggy013 Wrote: Glad they send you one Smile
Can you compare the speed of the "old" variant (1056) and the "new" variant (1560) on your quartz64, is there a difference between them?
There is no support for HDMI in the 5.10 kernel yet.
did try on
annoying you have to find extra configs trhrough commits or diffing .config Smile
4.19-193 raxda
4.19-206 firefly and patched firefly 150balbes-355xx-next
4.19-211 150balbes -35xx didnt find the origin 211 Smile
4.19.219 150balbes
4.19.219 latest from mirror 4.19
with uboot 3568 1560 ddr bin 1.11 and 1.12
&lpddr4_params {
/* freq info, freq_0 is final frequency, unit: MHz */
freq_0 = <1560>;
freq_1 = <324>;
freq_2 = <528>;
freq_3 = <780>;
&lpddr4x_params {
freq_0 = <1560>;
freq_1 = <324>;
freq_2 = <528>;
freq_3 = <780>;
and remove
&dmc {
system-status-freq = <
/*system status freq(KHz)*/
SYS_STATUS_NORMAL 780000
SYS_STATUS_REBOOT 1056000
SYS_STATUS_SUSPEND 324000
SYS_STATUS_VIDEO_1080P 528000
SYS_STATUS_BOOST 1056000
SYS_STATUS_ISP 1056000
SYS_STATUS_PERFORMANCE 1056000
&dmc_opp_table {
opp-1056000000 {
opp-hz = /bits/ 64 <1056000000>;
opp-microvolt = <900000>;
opp-microvolt-L0 = <900000>;
opp-microvolt-L1 = <850000>;
/delete-node/ opp-1560000000;
ow and
# CONFIG_DEVFREQ_EVENT_ROCKCHIP_NOCP is not set
did keep me a busy a while Smile
memtest runs nice on bsp Wink
ddrtest
glmark2
cpu stress
etc
(02-02-2022, 12:14 AM)balbes150 Wrote: There is no support for HDMI in the 5.10 kernel yet.
I believe that there is in 5.16 with VOP2 patches applied.
Source code is here https://gitlab.com/pgwipeout/linux-next/
By the way I have successfully installed Debian Buster on an eMMC quartz64 with the pgwipeout mainline kernel and it works beautifully, though I haven't yet tried HDMI out.
I am in the process of writing up instructions.
Essentially you do this:-
1. Partition your eMMC like this:-
https://wiki.pine64.org/wiki/Quartz64_In..._Linux_ARM
but be extremely careful about the "sdb" in the commands because if that's another drive in your desktop/laptop you are going to destroy the drive
2. Image this image to micro SD and boot:-
https://wiki.pine64.org/wiki/Quartz64#pg...uartz64_CI
it boots with a boot menu
With one of the options you can go to "debian installer"
Go through it all but at the partitioning menu select the root partition on the eMMC and install to that.
3. Reboot but on the boot menu select "recovery"
chroot into the eMMC and use dpkg to delete the kernel image packages.
exit chroot
Mount the boot partition on the eMMC and set up extlinux.conf and copy over the kernel and dtb file from the microSD card boot partition
these are only general instructions and I my intention is to write it up properly
debian is at bullseye Smile
https://deb.debian.org/debian/dists/bull...ion.img.gz
just do that instead of buster for the partion img in pg yaml file Wink
the bsp builds also with bullseye for a img
(02-06-2022, 02:39 PM)shaggy013 Wrote: debian is at bullseye Smile
Good point. I just updated it to bullseye and it seems happy.
huh hdmi just works in 5.10.66
https://drive.google.com/file/d/1PgXlNEv...sp=sharing
here a booting image for quartz64 with hdmi Smile
it is just the last 5.10.66 kernel and the 1560 uboot with my quartz64 dts with 4 reverted patches  ,
hdmi ,usb, lan ,wifi  works pcie not tested , only mpp and rga3 dont play nice well
so in rockchip_test the gl mark works the video test you see the mpp and rga trouble
(02-13-2022, 04:09 AM)shaggy013 Wrote: here a booting image for quartz64 with hdmi Smile
pcie does not work, trying to interact with a nvme ssd gives these sorts of errors
[  612.305740] nvme nvme0: I/O 21 QID 0 timeout, completion polled
[  613.764898] ITS queue timeout (5504 385)
[  613.764935] ITS cmd its_build_inv_cmd failed
[  675.451335] nvme nvme0: I/O 22 QID 0 timeout, completion polled
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 17,127 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,108 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 172,491 03-23-2025, 01:10 AM
Last Post: balbes150
  USB on Quartz64 Zero litbulb 0 1,549 11-13-2024, 08:16 AM
Last Post: litbulb
  DietPi OS for Quartz64 MichaIng 47 54,275 08-08-2024, 07:42 AM
Last Post: ifreislich
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 84,868 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 5,170 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 4,119 07-20-2023, 10:44 PM
Last Post: beepy
  Armbian RAM issue JambonLeVrai 2 5,204 02-12-2023, 06:48 AM
Last Post: diederik
  crux-arm Quartz64 RK3566 (aarch64) mara 5 10,463 10-29-2022, 06:55 AM
