Latest firmware for PinePhone modem!
#81
If you are Not having problems with your modem I would suggest staying with what works, or maybe the open source version when it matures a little bit.
The reason for changing it - would be to fix it or improve it.
I think my phone runs cooler now than it did a year ago... they are improving the software at an amazing rate.
---> I don't think I ever felt a cold smart phone.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(01-26-2022, 01:31 AM)bcnaz Wrote: If you are Not having problems with your modem I would suggest staying with what works, or maybe the open source version when it matures a little bit.
I don't know if I have problems with modem as I have just replaced the mainboard yesterday. Smile
I think a year ago it could easily became extremely hot, now it is simply really hot. Smile
Anyway, I think a general smartphone does not heat up to around 50 degree Celsius at around 21 degree Celsius room temperature when simply looking at its display and a terminal program... or who knows... Smile
However, open source version seems to be really good once it will have full and stable functionality.
They seem to manage modem's CPU frequency in a way it may run much cooler, I hope it will be the final and complete solution in the near future.
Anyway, what you feel cooler may be related to the newer firmwares discussed here?
What firmware are you using?
(01-25-2022, 08:07 PM)VaZso Wrote: It currently has modem firmware version EG25GGBR07A08M2G
https://wiki.pine64.org/wiki/PinePhone
command "AT+QGMR" also prints version, you only have type, in this case "EG25GGBR07A08M2G".
https://github.com/Biktorgj/quectel_eg25_recovery
this site has multiple stock firmware options, but it boils down to 01.002.01.002 , 01.003.01.003 , 30.004.30.004 . devs recommend 01.002.01.002. but i'm testing 30.004.30.004 at a moment.
my view, they all equally bad. one firmware may fix something and others may fix other issues.
and usual biological thermal nuclear explosion warnings. updating modem firmware is one's own responsibility. usually in bad case modem just becomes brick but if biological thermal implosion occurs then it's not my fault or dev's fault.
30.004.30.004 how it works for you ? are there any problems?
(01-26-2022, 09:33 AM)zetabeta Wrote: command "AT+QGMR" also prints version, you only have type, in this case "EG25GGBR07A08M2G".
Thank you.
Sorry, it has firmware version EG25GGBR07A08M2G_01.002.01.002
Firmware version :   EG25GGBR07A08M2G
The same firmware is in all my 3 PMOS Convergent phones and in my 1 Manjaro Convergent phone.
Me ?  I think it is the improved software that has lowered the operating temperature...  But, that is just my opinion though.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(01-26-2022, 03:39 PM)kubussz Wrote: 30.004.30.004 how it works for you ? are there any problems?
too early to tell. but it won't jam or crash instantly. sleep or suspend is not tested, because those are headaches for my use case.
https://forum.pine64.org/showthread.php?...#pid103530
previous is not firmware issue, but might be helpful.
You use firmware custom or stock?
(01-27-2022, 01:08 PM)kubussz Wrote: You use firmware custom or stock?
stock, https://github.com/Biktorgj/quectel_eg25...004.30.004 .
(01-27-2022, 01:17 PM)zetabeta Wrote: stock, https://github.com/Biktorgj/quectel_eg25...004.30.004 .
I use custom and I afraid of how it will work on 30.004.30.004
  asterisk or FreePBX on pinephone? vanja 0 57 Yesterday, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 21,982 Yesterday, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 6,419 06-04-2026, 02:10 AM
Last Post: merom
  Fedora + Phosh for PinePhone njha 77 215,910 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 713 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,851 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 63,859 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 5,161 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 71,923 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 6,845 07-04-2024, 07:34 AM
