Are you OK with the size of the PinePhone?
It's too small, I would like to have a PinePhone "Max"
11.76%
4
I'm perfectly fine with the size
58.82%
20
It's too tall, I would like to have a PinePhone "Mini"
23.53%
8
I don't care
5.88%
2
34 vote(s)
I think the size is fine, smaller harder to read, bigger hard to carry.
I wouldn't mind thicker.
Would appreciate a higher resolution, but proper scaling in the SW should tackle my problems.
I like the idea to use as PC, it would be(come) usable with a USB dongle,
but (once the keyboard arrives) it is also usable on the road for simple tasks.
I like the idea of getting an additional phablet size but I think having a 10" ereader is more important than a tablet of phablet.
Although I would like to connect a keyboard (like the pinetab) to the ereader, but for now BT has to do just fine.
(12-14-2021, 08:48 AM)thefunnyman Wrote: The screen resolution is definetly too low though.
For what use is the resolution too low? To make out individual pixels I have to bring the screen really close to my eyes. I don't think such a small screen would benefit much from a higher resolution (not to speak of the energy tradeoff).
(12-14-2021, 05:15 AM)zetabeta Wrote:
(12-14-2021, 03:17 AM)bcnaz Wrote: ... Get a feature/Message phone.!
i don't like to irritate but can you suggest a good one. even many basic phones are based on smartphone o.s. with some annoyances or does not have volte. volte starting to be requirement even for dumb-phones.
I had to replace my 8 year old Samsung flip phone last month because it was 3G, and after January, I would need 4G.
Found this Coolpad flip phone thing that is so so. It is 4G and will do WiFi calling with Boost, (aka T-Mobile). It even has a SDXC card slot inside that allows you to listen to music and such. Their is a camera. The interface is a noticeably slow, but usable for casual use. Any extensive use I might be more annoyed with the sluggishness. It's bigger in all directions than my old Samsung flip phone. Plus, it's battery needs charging every few days, (compared to at least a week to the Samsung flip phone). But, it will fit in most pockets just fine, with the primary screen and keyboard protected when closed. Don't know if it has VoLTE... not sure how that is defined.
https://www.amazon.com/gp/product/B08GM7DRXM
Not sure I would suggest / recommend this Coolpad phone. It works for me, for the moment.
Now that you all think I am a Luddite, I do have an Android phone. Its just that without a land line, I don't have a backup. Thus, 2 cell-phones.
Arwen Evenstar
Princess of Rivendale
@Arwen Thank you for the hint. But Android.....NO. There I can equal reactivate my iPhone.
(12-15-2021, 02:55 PM)guenther Wrote: @Arwen Thank you for the hint. But Android.....NO. There I can equal reactivate my iPhone.
yes, it is android, but it (probably) is de-googled android with modifications.
  Zig booting up on PinePhone WhiteHexagon 0 2,389 07-19-2025, 03:11 AM
Last Post: WhiteHexagon
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 2,818 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Second-Hand PinePhone rdv 9 5,426 01-05-2025, 11:42 PM
  pinephone 3 ideas aular 5 4,995 11-08-2024, 06:35 AM
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 2,944 04-11-2024, 03:10 PM
  Where PinePhone Pro are Made Tony90 1 3,287 01-18-2024, 09:20 AM
  using Zoom on Pinephone andrew907 5 4,693 12-09-2023, 01:26 AM
Last Post: crocspot
  Does pinephone allow you to repair your own device as easily as fairphone? unix21311 3 4,971 11-06-2022, 10:37 PM
Last Post: Harolddavies0
  can i install mobian on pinephone? luofeiyu 2 3,197 10-15-2022, 07:31 AM
Last Post: user641
  Does the pinephone have hardware kill switches located on the outside of the phone? unix21311 2 7,401 10-03-2022, 05:53 AM
Last Post: unix21311
