slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64)
#21
working HDMI
slarm64-current-aarch64-server-quartz64-5.16.0-rc2-build-20211201.img.zst
slarm64-current-aarch64-server-quartz64-5.16.0-rc2-build-20211201.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-5.16.0-rc2-build-20211201.img.zst
slarm64-current-aarch64-xfce-quartz64-5.16.0-rc2-build-20211201.img.zst.sha256
donation   irradium
(12-01-2021, 12:52 AM)mara Wrote: working HDMI
testing now will let you know how it goes
edit: it is working so far. I had the battery jumper off. installing it/shorting it, it now boots
so i have to do this
  # zstd -d slackware-current-*-server-*-build-*.img
  # dd if=slackware-current-*-server-*-build-*.img of=/dev/mmcblk0 bs=1M
if i try this
   sudo zstdcat slackware-current-*-server-*-build-*.img.zst > /dev/mmcblk0
i get "permission denied"
(12-01-2021, 12:57 PM)keaton Wrote: if i try this
Because in the latter example, you're only running the cat as root, not the shell redirect. Don't use sudo here, do sudo -i first to get a root shell.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
update kernel 5.16-rc4
slarm64-current-aarch64-server-quartz64-5.16.0-rc4-build-20211206.img.zst
slarm64-current-aarch64-server-quartz64-5.16.0-rc4-build-20211206.img.zst.sha256
slarm64-current-aarch64-xfce-quartz64-5.16.0-rc4-build-20211206.img.zst
slarm64-current-aarch64-xfce-quartz64-5.16.0-rc4-build-20211206.img.zst.sha256
donation   irradium
(12-06-2021, 05:50 AM)mara Wrote: slarm64-current-aarch64-xfce-quartz64-5.16.0-rc4-build-20211206.img.zst
It boots and runs but I have no HDMI output.
I don't know if there are any clues in here:-
root@quartz64:/var/log# cat Xorg.0.log
[    41.517]
X.Org X Server 1.20.13
X Protocol Version 11, Revision 0
[    41.517] Build Operating System: Slackware 15.0 Slackware Linux Project
[    41.517] Current Operating System: Linux quartz64 5.16.0-rc4 #1 SMP PREEMPT Sun Dec 5 23:15:25 UTC 2021 aarch64
[    41.517] Kernel command line: root=/dev/mmcblk0p2 ro rootwait rootfstype=ext4 init=/sbin/init loglevel=4 earlycon=u8
[    41.518] Build Date: 30 July 2021  08:16:48PM
[    41.518]
[    41.518] Current version of pixman: 0.40.0
[    41.518]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[    41.518] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    41.518] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec  6 10:14:45 2021
[    41.524] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    41.524] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    41.539] (==) No Layout section.  Using the first Screen section.
[    41.539] (==) No screen section available. Using defaults.
[    41.539] (**) |-->Screen "Default Screen Section" (0)
[    41.539] (**) |   |-->Monitor "<default monitor>"
[    41.540] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[    41.541] (**) Option "BlankTime" "0"
[    41.541] (**) Option "StandbyTime" "0"
[    41.541] (**) Option "SuspendTime" "0"
[    41.541] (**) Option "OffTime" "0"
[    41.541] (==) Automatically adding devices
[    41.541] (==) Automatically enabling devices
[    41.541] (==) Automatically adding GPU devices
[    41.541] (==) Automatically binding GPU devices
[    41.541] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    41.541] (WW) The directory "/usr/share/fonts/local" does not exist.
[    41.541]    Entry deleted from font path.
[    41.542] (WW) The directory "/usr/share/fonts/CID" does not exist.
[    41.542]    Entry deleted from font path.
[    41.551] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF,
        /usr/share/fonts/OTF,
        /usr/share/fonts/Type1,
        /usr/share/fonts/75dpi/:unscaled,
        /usr/share/fonts/100dpi/:unscaled,
        /usr/share/fonts/75dpi,
        /usr/share/fonts/100dpi,
        /usr/share/fonts/cyrillic
[    41.551] (==) ModulePath set to "/usr/lib64/xorg/modules"
[    41.551] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[    41.551] (II) Loader magic: 0x624c30
[    41.551] (II) Module ABI versions:
[    41.551]    X.Org ANSI C Emulation: 0.4
[    41.551]    X.Org Video Driver: 24.1
[    41.551]    X.Org XInput driver : 24.1
[    41.551]    X.Org Server Extension : 10.0
[    41.553] (II) xfree86: Adding drm device (/dev/dri/card0)
[    41.555] (II) no primary bus or device found
[    41.555]    falling back to /sys/devices/platform/display-subsystem/drm/card0
[    41.555] (II) LoadModule: "glx"
[    41.565] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[    41.579] (II) Module glx: vendor="X.Org Foundation"
[    41.579]    compiled for 1.20.13, module version = 1.0.0
[    41.579]    ABI class: X.Org Server Extension, version 10.0
[    41.579] (==) Matched modesetting as autoconfigured driver 0
[    41.579] (==) Matched fbdev as autoconfigured driver 1
[    41.579] (==) Assigned the driver to the xf86ConfigLayout
[    41.579] (II) LoadModule: "modesetting"
[    41.581] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[    41.584] (II) Module modesetting: vendor="X.Org Foundation"
[    41.584]    compiled for 1.20.13, module version = 1.20.13
[    41.584]    Module class: X.Org Video Driver
[    41.585]    ABI class: X.Org Video Driver, version 24.1
[    41.585] (II) LoadModule: "fbdev"
[    41.585] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[    41.587] (II) Module fbdev: vendor="X.Org Foundation"
[    41.587]    compiled for 1.20.9, module version = 0.5.0
[    41.587]    Module class: X.Org Video Driver
[    41.587]    ABI class: X.Org Video Driver, version 24.1
[    41.588] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    41.588] (II) FBDEV: driver for framebuffer: fbdev
[    41.588] (++) using VT number 7
[    41.593] (II) modeset(0): using drv /dev/dri/card0
[    41.593] (WW) Falling back to old probe method for fbdev
[    41.593] (II) Loading sub module "fbdevhw"
[    41.593] (II) LoadModule: "fbdevhw"
[    41.595] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[    41.597] (II) Module fbdevhw: vendor="X.Org Foundation"
[    41.597]    compiled for 1.20.13, module version = 0.0.2
[    41.597]    ABI class: X.Org Video Driver, version 24.1
[    41.598] (EE) open /dev/fb0: No such file or directory
[    41.598] (II) modeset(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[    41.598] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    41.598] (==) modeset(0): RGB weight 888
[    41.598] (==) modeset(0): Default visual is TrueColor
[    41.599] (II) Loading sub module "glamoregl"
[    41.599] (II) LoadModule: "glamoregl"
[    41.599] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[    41.679] (II) Module glamoregl: vendor="X.Org Foundation"
[    41.679]    compiled for 1.20.13, module version = 1.0.1
[    41.679]    ABI class: X.Org ANSI C Emulation, version 0.4
[    44.159] (II) modeset(0): Refusing to try glamor on llvmpipe
[    44.166] (EE) modeset(0): glamor initialization failed
[    44.166] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[    44.166] (II) modeset(0): Output HDMI-1 has no monitor section
[    44.167] (II) modeset(0): EDID for output HDMI-1
[    44.167] (II) modeset(0): Output HDMI-1 disconnected
[    44.167] (WW) modeset(0): No outputs definitely connected, trying again...
[    44.167] (WW) modeset(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
[    44.167] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    44.167] (==) modeset(0): DPI set to (96, 96)
[    44.167] (II) Loading sub module "fb"
[    44.167] (II) LoadModule: "fb"
[    44.168] (II) Loading /usr/lib64/xorg/modules/libfb.so
[    44.174] (II) Module fb: vendor="X.Org Foundation"
[    44.174]    compiled for 1.20.13, module version = 1.0.0
[    44.174]    ABI class: X.Org ANSI C Emulation, version 0.4
[    44.174] (II) UnloadModule: "fbdev"
[    44.175] (II) Unloading fbdev
[    44.175] (II) UnloadSubModule: "fbdevhw"
[    44.175] (II) Unloading fbdevhw
[    44.188] (==) modeset(0): Backing store enabled
[    44.188] (==) modeset(0): Silken mouse enabled
[    44.191] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    44.192] (==) modeset(0): DPMS enabled
[    44.192] (II) Initializing extension Generic Event Extension
[    44.192] (II) Initializing extension SHAPE
[    44.192] (II) Initializing extension MIT-SHM
[    44.192] (II) Initializing extension XInputExtension
[    44.194] (II) Initializing extension XTEST
[    44.194] (II) Initializing extension BIG-REQUESTS
[    44.194] (II) Initializing extension SYNC
[    44.194] (II) Initializing extension XKEYBOARD
[    44.194] (II) Initializing extension XC-MISC
[    44.194] (II) Initializing extension XFIXES
[    44.194] (II) Initializing extension RENDER
[    44.194] (II) Initializing extension RANDR
[    44.194] (II) Initializing extension COMPOSITE
[    44.194] (II) Initializing extension DAMAGE
[    44.195] (II) Initializing extension MIT-SCREEN-SAVER
[    44.195] (II) Initializing extension DOUBLE-BUFFER
[    44.195] (II) Initializing extension RECORD
[    44.195] (II) Initializing extension DPMS
[    44.195] (II) Initializing extension Present
[    44.195] (II) Initializing extension DRI3
[    44.195] (II) Initializing extension X-Resource
[    44.195] (II) Initializing extension XVideo
[    44.195] (II) Initializing extension XVideo-MotionCompensation
[    44.195] (II) Initializing extension GLX
[    44.195] (II) AIGLX: Screen 0 is not DRI2 capable
[    44.353] (II) IGLX: Loaded and initialized swrast
[    44.353] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    44.353] (II) Initializing extension XFree86-VidModeExtension
[    44.353] (II) Initializing extension XFree86-DGA
[    44.354] (II) Initializing extension XFree86-DRI
[    44.355] (II) Initializing extension DRI2
[    44.356] (II) modeset(0): Damage tracking initialized
[    45.105] (II) config/udev: Adding input device Logitech K400 Plus (/dev/input/event1)
[    45.105] (**) Logitech K400 Plus: Applying InputClass "evdev pointer catchall"
[    45.105] (**) Logitech K400 Plus: Applying InputClass "evdev keyboard catchall"
[    45.105] (**) Logitech K400 Plus: Applying InputClass "libinput pointer catchall"
[    45.106] (**) Logitech K400 Plus: Applying InputClass "libinput keyboard catchall"
[    45.106] (**) Logitech K400 Plus: Applying InputClass "keyboard-all"
[    45.106] (II) LoadModule: "libinput"
[    45.107] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[    45.130] (II) Module libinput: vendor="X.Org Foundation"
[    45.130]    compiled for 1.20.13, module version = 1.2.0
[    45.130]    Module class: X.Org XInput Driver
[    45.130]    ABI class: X.Org XInput driver, version 24.1
[    45.130] (II) Using input driver 'libinput' for 'Logitech K400 Plus'
[    45.130] (**) Logitech K400 Plus: always reports core events
[    45.130] (**) Option "Device" "/dev/input/event1"
[    45.132] (**) Option "_source" "server/udev"
[    45.167] (II) event1  - Logitech K400 Plus: is tagged by udev as: Keyboard Mouse
[    45.168] (II) event1  - Logitech K400 Plus: device is a pointer
[    45.168] (II) event1  - Logitech K400 Plus: device is a keyboard
[    45.169] (II) event1  - Logitech K400 Plus: device removed
[    45.241] (II) libinput: Logitech K400 Plus: needs a virtual subdevice
[    45.241] (**) Option "config_info" "udev:/sys/devices/platform/fd840000.usb/usb3/3-1/3-1:1.2/0003:046D:C52B.0003/00"
[    45.241] (II) XINPUT: Adding extended input device "Logitech K400 Plus" (type: MOUSE, id 6)
[    45.242] (**) Option "AccelerationScheme" "none"
[    45.242] (**) Logitech K400 Plus: (accel) selected scheme none/0
[    45.243] (**) Logitech K400 Plus: (accel) acceleration factor: 2.000
[    45.243] (**) Logitech K400 Plus: (accel) acceleration threshold: 4
[    45.247] (II) event1  - Logitech K400 Plus: is tagged by udev as: Keyboard Mouse
[    45.247] (II) event1  - Logitech K400 Plus: device is a pointer
[    45.247] (II) event1  - Logitech K400 Plus: device is a keyboard
[    45.250] (II) config/udev: Adding input device Logitech K400 Plus (/dev/input/mouse0)
[    45.250] (II) No input driver specified, ignoring this device.
[    45.250] (II) This device may have been added with another device file.
[    45.252] (II) config/udev: Adding input device Analog RK817 Headphones (/dev/input/event0)
[    45.252] (II) No input driver specified, ignoring this device.
[    45.253] (II) This device may have been added with another device file.
[    45.282] (**) Logitech K400 Plus: Applying InputClass "evdev pointer catchall"
[    45.282] (**) Logitech K400 Plus: Applying InputClass "evdev keyboard catchall"
[    45.283] (**) Logitech K400 Plus: Applying InputClass "libinput pointer catchall"
[    45.283] (**) Logitech K400 Plus: Applying InputClass "libinput keyboard catchall"
[    45.283] (**) Logitech K400 Plus: Applying InputClass "keyboard-all"
[    45.283] (II) Using input driver 'libinput' for 'Logitech K400 Plus'
[    45.283] (**) Logitech K400 Plus: always reports core events
[    45.283] (**) Option "Device" "/dev/input/event1"
[    45.283] (**) Option "_source" "_driver/libinput"
[    45.283] (II) libinput: Logitech K400 Plus: is a virtual subdevice
[    45.283] (**) Option "config_info" "udev:/sys/devices/platform/fd840000.usb/usb3/3-1/3-1:1.2/0003:046D:C52B.0003/00"
[    45.284] (II) XINPUT: Adding extended input device "Logitech K400 Plus" (type: KEYBOARD, id 7)
[    45.284] (**) Option "xkb_layout" "us"
[    45.284] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
I'm fine with the output to HDMI
[    46.222]
[    46.222] Build Operating System: Slackware 15.0 Slackware Linux Project
[    46.222] Current Operating System: Linux quartz64 5.16.0-rc4 #1 SMP PREEMPT Sun Dec 5 23:15:25 UTC 2021 aarch64
[    46.222] Kernel command line: root=/dev/mmcblk0p2 ro rootwait rootfstype=ext4 init=/sbin/init loglevel=4 earlycon=uart8250,mmio32,0xfe660000 console=tty1 console=ttyS2,1500000n8
[    46.222] Build Date: 30 July 2021  08:16:48PM
[    46.222]
[    46.222] Current version of pixman: 0.40.0
[    46.222]     Before reporting problems, check http://wiki.x.org
[    46.222] Markers: (--) probed, (**) from config file, (==) default setting,
[    46.223] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Aug  5 09:01:54 2017
[    46.227] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    46.227] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    46.234] (==) No Layout section.  Using the first Screen section.
[    46.234] (==) No screen section available. Using defaults.
[    46.234] (**) |-->Screen "Default Screen Section" (0)
[    46.234] (**) |   |-->Monitor "<default monitor>"
[    46.235] (==) No monitor specified for screen "Default Screen Section".
[    46.236] (**) Option "BlankTime" "0"
[    46.236] (**) Option "StandbyTime" "0"
[    46.236] (**) Option "SuspendTime" "0"
[    46.236] (**) Option "OffTime" "0"
[    46.236] (==) Automatically adding devices
[    46.236] (==) Automatically enabling devices
[    46.236] (==) Automatically adding GPU devices
[    46.236] (==) Automatically binding GPU devices
[    46.236] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    46.236] (WW) The directory "/usr/share/fonts/local" does not exist.
[    46.236]     Entry deleted from font path.
[    46.237] (WW) The directory "/usr/share/fonts/CID" does not exist.
[    46.237]     Entry deleted from font path.
[    46.247] (==) FontPath set to:
[    46.247] (==) ModulePath set to "/usr/lib64/xorg/modules"
[    46.247] (II) The server relies on udev to provide the list of input devices.
[    46.247] (II) Loader magic: 0x624c30
[    46.247] (II) Module ABI versions:
[    46.247]     X.Org ANSI C Emulation: 0.4
[    46.247]     X.Org Video Driver: 24.1
[    46.248]     X.Org XInput driver : 24.1
[    46.248]     X.Org Server Extension : 10.0
[    46.249] (II) xfree86: Adding drm device (/dev/dri/card0)
[    46.265] (II) no primary bus or device found
[    46.265]     falling back to /sys/devices/platform/display-subsystem/drm/card0
[    46.265] (II) LoadModule: "glx"
[    46.270] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[    46.281] (II) Module glx: vendor="X.Org Foundation"
[    46.281]     compiled for 1.20.13, module version = 1.0.0
[    46.281]     ABI class: X.Org Server Extension, version 10.0
[    46.281] (==) Matched modesetting as autoconfigured driver 0
[    46.282] (==) Matched fbdev as autoconfigured driver 1
[    46.282] (==) Assigned the driver to the xf86ConfigLayout
[    46.282] (II) LoadModule: "modesetting"
[    46.283] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[    46.288] (II) Module modesetting: vendor="X.Org Foundation"
[    46.288]     compiled for 1.20.13, module version = 1.20.13
[    46.288]     Module class: X.Org Video Driver
[    46.288]     ABI class: X.Org Video Driver, version 24.1
[    46.288] (II) LoadModule: "fbdev"
[    46.289] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[    46.291] (II) Module fbdev: vendor="X.Org Foundation"
[    46.291]     compiled for 1.20.9, module version = 0.5.0
[    46.291]     Module class: X.Org Video Driver
[    46.291]     ABI class: X.Org Video Driver, version 24.1
[    46.291] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    46.291] (II) FBDEV: driver for framebuffer: fbdev
[    46.291] (++) using VT number 7
[    46.347] (II) modeset(0): using drv /dev/dri/card0
[    46.347] (WW) Falling back to old probe method for fbdev
[    46.347] (II) Loading sub module "fbdevhw"
[    46.347] (II) LoadModule: "fbdevhw"
[    46.349] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[    46.351] (II) Module fbdevhw: vendor="X.Org Foundation"
[    46.352]     compiled for 1.20.13, module version = 0.0.2
[    46.352]     ABI class: X.Org Video Driver, version 24.1
[    46.352] (II) modeset(0): Creating default Display subsection in Screen section
[    46.352] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[    46.353] (==) modeset(0): RGB weight 888
[    46.353] (==) modeset(0): Default visual is TrueColor
[    46.353] (II) Loading sub module "glamoregl"
[    46.353] (II) LoadModule: "glamoregl"
[    46.354] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[    46.392] (II) Module glamoregl: vendor="X.Org Foundation"
[    46.392]     compiled for 1.20.13, module version = 1.0.1
[    46.392]     ABI class: X.Org ANSI C Emulation, version 0.4
[    48.670] (II) modeset(0): Refusing to try glamor on llvmpipe
[    48.677] (EE) modeset(0): glamor initialization failed
[    48.677] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[    48.788] (II) modeset(0): Output HDMI-1 has no monitor section
[    48.899] (II) modeset(0): EDID for output HDMI-1
[    48.899] (II) modeset(0): Manufacturer: SAM  Model: f57  Serial#: 810834008
[    48.899] (II) modeset(0): Year: 2019  Week: 26
[    48.899] (II) modeset(0): EDID Version: 1.3
[    48.899] (II) modeset(0): Digital Display Input
[    48.899] (II) modeset(0): Max Image Size [cm]: horiz.: 60  vert.: 34
[    48.900] (II) modeset(0): Gamma: 2.20
[    48.900] (II) modeset(0): DPMS capabilities: Off
[    48.900] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    48.900] (II) modeset(0): First detailed timing is preferred mode
[    48.900] (II) modeset(0): redX: 0.652 redY: 0.341   greenX: 0.320 greenY: 0.608
[    48.900] (II) modeset(0): blueX: 0.146 blueY: 0.065   whiteX: 0.313 whiteY: 0.329
[    48.900] (II) modeset(0): Supported established timings:
[    48.900] (II) modeset(0): 720x400@70Hz
[    48.900] (II) modeset(0): 640x480@60Hz
[    48.900] (II) modeset(0): 640x480@67Hz
[    48.900] (II) modeset(0): 640x480@72Hz
[    48.900] (II) modeset(0): 640x480@75Hz
[    48.900] (II) modeset(0): 800x600@56Hz
[    48.900] (II) modeset(0): 800x600@60Hz
[    48.900] (II) modeset(0): 800x600@72Hz
[    48.900] (II) modeset(0): 800x600@75Hz
[    48.900] (II) modeset(0): 832x624@75Hz
[    48.900] (II) modeset(0): 1024x768@60Hz
[    48.900] (II) modeset(0): 1024x768@70Hz
[    48.900] (II) modeset(0): 1024x768@75Hz
[    48.900] (II) modeset(0): 1280x1024@75Hz
[    48.900] (II) modeset(0): 1152x864@75Hz
[    48.901] (II) modeset(0): Manufacturer's mask: 0
[    48.901] (II) modeset(0): Supported standard timings:
[    48.901] (II) modeset(0): #0: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[    48.901] (II) modeset(0): #1: hsize: 1280  vsize 800  refresh: 60  vid: 129
[    48.901] (II) modeset(0): #2: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[    48.901] (II) modeset(0): #3: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    48.901] (II) modeset(0): #4: hsize: 1440  vsize 900  refresh: 60  vid: 149
[    48.901] (II) modeset(0): #5: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[    48.901] (II) modeset(0): #6: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[    48.901] (II) modeset(0): Supported detailed timing:
[    48.901] (II) modeset(0): clock: 241.5 MHz   Image Size:  597 x 336 mm
[    48.901] (II) modeset(0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[    48.901] (II) modeset(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[    48.901] (II) modeset(0): Ranges: V min: 50 V max: 75 Hz, H min: 27 H max: 89 kHz, PixClock max 255 MHz
[    48.901] (II) modeset(0): Monitor name: C27JG5x
[    48.901] (II) modeset(0): Serial No: HTOM601358
[    48.901] (II) modeset(0): clock: 148.5 MHz   Image Size:  597 x 336 mm
[    48.901] (II) modeset(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[    48.901] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[    48.902] (II) modeset(0): Supported detailed timing:
[    48.902] (II) modeset(0): clock: 148.5 MHz   Image Size:  597 x 336 mm
[    48.902] (II) modeset(0): h_active: 1920  h_sync: 2448  h_sync_end 2492 h_blank_end 2640 h_border: 0
[    48.902] (II) modeset(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[    48.902] (II) modeset(0): clock: 74.2 MHz   Image Size:  597 x 336 mm
[    48.902] (II) modeset(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[    48.902] (II) modeset(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[    48.902] (II) modeset(0): h_active: 1280  h_sync: 1720  h_sync_end 1760 h_blank_end 1980 h_border: 0
[    48.902] (II) modeset(0): clock: 27.0 MHz   Image Size:  597 x 336 mm
[    48.902] (II) modeset(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[    48.902] (II) modeset(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[    48.902] (II) modeset(0): Number of EDID sections to follow: 1
[    48.902] (II) modeset(0): EDID (in hex):
[    48.902] (II) modeset(0):     00ffffffffffff004c2d570f58585430
[    48.902] (II) modeset(0):     1a1d0103803c22782a1375a757529b25
[    48.903] (II) modeset(0):     105054bfef80b300810081c081809500
[    48.903] (II) modeset(0):     a9c0714f0101565e00a0a0a029503020
[    48.903] (II) modeset(0):     350055502100001a000000fd00324b1b
[    48.903] (II) modeset(0):     5919000a202020202020000000fc0043
[    48.903] (II) modeset(0):     32374a4735780a2020202020000000ff
[    48.903] (II) modeset(0):     0048544f4d3630313335380a202001fc
[    48.903] (II) modeset(0):     02031bf146901f041303122309070783
[    48.903] (II) modeset(0):     01000067030c0020008032023a801871
[    48.903] (II) modeset(0):     382d40582c450055502100001e023a80
[    48.903] (II) modeset(0):     d072382d40102c458055502100001e01
[    48.903] (II) modeset(0):     1d007251d01e206e2855005550210000
[    48.903] (II) modeset(0):     1e011d00bc52d01e20b8285540555021
[    48.903] (II) modeset(0):     00001e8c0ad08a20e02d10103e960055
[    48.903] (II) modeset(0):     50210000180000000000000000000069
[    48.903] (--) modeset(0): HDMI max TMDS frequency 250000KHz
[    48.904] (II) modeset(0): Printing probed modes for output HDMI-1
[    48.904] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    48.904] (II) modeset(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    48.904] (II) modeset(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 1800  900 901 904 1000 +hsync +vsync (60.0 kHz e)
[    48.904] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    48.904] (II) modeset(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    48.904] (II) modeset(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    48.904] (II) modeset(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    48.904] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    48.904] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    48.904] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    48.904] (II) modeset(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    48.904] (II) modeset(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    48.904] (II) modeset(0): Output HDMI-1 connected
[    48.904] (II) modeset(0): Using exact sizes for initial modes
[    48.904] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[    48.905] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    48.905] (==) modeset(0): DPI set to (96, 96)
[    48.905] (II) Loading sub module "fb"
[    48.905] (II) LoadModule: "fb"
[    48.906] (II) Loading /usr/lib64/xorg/modules/libfb.so
[    48.915] (II) Module fb: vendor="X.Org Foundation"
[    48.915]     compiled for 1.20.13, module version = 1.0.0
[    48.915]     ABI class: X.Org ANSI C Emulation, version 0.4
[    48.915] (II) UnloadModule: "fbdev"
[    48.915] (II) Unloading fbdev
[    48.915] (II) UnloadSubModule: "fbdevhw"
[    48.915] (II) Unloading fbdevhw
[    48.938] (==) modeset(0): Backing store enabled
[    48.938] (==) modeset(0): Silken mouse enabled
[    48.947] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    48.947] (==) modeset(0): DPMS enabled
[    48.948] (II) Initializing extension Generic Event Extension
[    48.948] (II) Initializing extension SHAPE
[    48.948] (II) Initializing extension MIT-SHM
[    48.948] (II) Initializing extension XInputExtension
[    48.950] (II) Initializing extension XTEST
[    48.950] (II) Initializing extension BIG-REQUESTS
[    48.950] (II) Initializing extension SYNC
[    48.950] (II) Initializing extension XKEYBOARD
[    48.950] (II) Initializing extension XC-MISC
[    48.950] (II) Initializing extension XFIXES
[    48.950] (II) Initializing extension RENDER
[    48.950] (II) Initializing extension RANDR
[    48.950] (II) Initializing extension COMPOSITE
[    48.950] (II) Initializing extension DAMAGE
[    48.951] (II) Initializing extension MIT-SCREEN-SAVER
[    48.951] (II) Initializing extension DOUBLE-BUFFER
[    48.951] (II) Initializing extension RECORD
[    48.951] (II) Initializing extension DPMS
[    48.951] (II) Initializing extension Present
[    48.951] (II) Initializing extension DRI3
[    48.951] (II) Initializing extension X-Resource
[    48.951] (II) Initializing extension XVideo
[    48.951] (II) Initializing extension XVideo-MotionCompensation
[    48.951] (II) Initializing extension GLX
[    48.951] (II) AIGLX: Screen 0 is not DRI2 capable
[    49.132] (II) IGLX: Loaded and initialized swrast
[    49.132] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    49.132] (II) Initializing extension XFree86-VidModeExtension
[    49.132] (II) Initializing extension XFree86-DGA
[    49.132] (II) Initializing extension XFree86-DRI
[    49.133] (II) Initializing extension DRI2
[    49.136] (II) modeset(0): Damage tracking initialized
[    49.136] (II) modeset(0): Setting screen physical size to 508 x 285
[    49.905] (II) config/udev: Adding input device Analog RK817 Headphones (/dev/input/event0)
[    49.905] (II) No input driver specified, ignoring this device.
[    49.905] (II) This device may have been added with another device file.
[    64.810] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[    64.810] (II) No input driver specified, ignoring this device.
[    64.810] (II) This device may have been added with another device file.
[    64.937] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event1)
[    64.937] (**) Logitech USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[    64.937] (**) Logitech USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[    64.937] (II) LoadModule: "libinput"
[    64.938] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[    64.966] (II) Module libinput: vendor="X.Org Foundation"
[    64.966]     compiled for 1.20.13, module version = 1.2.0
[    64.966]     Module class: X.Org XInput Driver
[    64.966]     ABI class: X.Org XInput driver, version 24.1
[    64.966] (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
[    64.966] (**) Logitech USB Optical Mouse: always reports core events
[    64.966] (**) Option "Device" "/dev/input/event1"
[    64.968] (**) Option "_source" "server/udev"
[    65.008] (II) event1  - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[    65.009] (II) event1  - Logitech USB Optical Mouse: device is a pointer
[    65.010] (II) event1  - Logitech USB Optical Mouse: device removed
[    65.121] (**) Option "config_info" "udev:/sys/devices/platform/fd800000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C077.0001/input/input1/event1"
[    65.121] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 6)
[    65.122] (**) Option "AccelerationScheme" "none"
[    65.122] (**) Logitech USB Optical Mouse: (accel) selected scheme none/0
[    65.123] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[    65.123] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[    65.127] (II) event1  - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[    65.127] (II) event1  - Logitech USB Optical Mouse: device is a pointer
[    65.132] (II) event1  - Logitech USB Optical Mouse: SYN_DROPPED event - some input events have been lost.
[    65.349] (II) config/udev: Adding input device Logitech USB Keyboard System Control (/dev/input/event4)
[    65.349] (**) Logitech USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[    65.349] (**) Logitech USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[    65.349] (**) Logitech USB Keyboard System Control: Applying InputClass "keyboard-all"
[    65.349] (II) Using input driver 'libinput' for 'Logitech USB Keyboard System Control'
[    65.349] (**) Logitech USB Keyboard System Control: always reports core events
[    65.349] (**) Option "Device" "/dev/input/event4"
[    65.349] (**) Option "_source" "server/udev"
[    65.354] (II) event4  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[    65.354] (II) event4  - Logitech USB Keyboard System Control: device is a keyboard
[    65.355] (II) event4  - Logitech USB Keyboard System Control: device removed
[    65.410] (**) Option "config_info" "udev:/sys/devices/platform/fd800000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C31C.0003/input/input4/event4"
[    65.410] (II) XINPUT: Adding extended input device "Logitech USB Keyboard System Control" (type: KEYBOARD, id 7)
[    65.410] (**) Option "xkb_layout" "us"
[    65.410] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    65.554] (II) event4  - Logitech USB Keyboard System Control: is tagged by udev as: Keyboard
[    65.555] (II) event4  - Logitech USB Keyboard System Control: device is a keyboard
[    65.565] (II) config/udev: Adding input device Logitech USB Keyboard (/dev/input/event2)
[    65.565] (**) Logitech USB Keyboard: Applying InputClass "evdev keyboard catchall"
[    65.566] (**) Logitech USB Keyboard: Applying InputClass "libinput keyboard catchall"
[    65.566] (**) Logitech USB Keyboard: Applying InputClass "keyboard-all"
[    65.566] (II) Using input driver 'libinput' for 'Logitech USB Keyboard'
[    65.566] (**) Logitech USB Keyboard: always reports core events
[    65.566] (**) Option "Device" "/dev/input/event2"
[    65.566] (**) Option "_source" "server/udev"
[    65.570] (II) event2  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[    65.570] (II) event2  - Logitech USB Keyboard: device is a keyboard
[    65.571] (II) event2  - Logitech USB Keyboard: device removed
[    65.620] (**) Option "config_info" "udev:/sys/devices/platform/fd800000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C31C.0002/input/input2/event2"
[    65.620] (II) XINPUT: Adding extended input device "Logitech USB Keyboard" (type: KEYBOARD, id 8)
[    65.620] (**) Option "xkb_layout" "us"
[    65.620] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    65.625] (II) event2  - Logitech USB Keyboard: is tagged by udev as: Keyboard
[    65.625] (II) event2  - Logitech USB Keyboard: device is a keyboard
[    65.632] (II) config/udev: Adding input device Logitech USB Keyboard Consumer Control (/dev/input/event3)
[    65.632] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[    65.632] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[    65.632] (**) Logitech USB Keyboard Consumer Control: Applying InputClass "keyboard-all"
[    65.632] (II) Using input driver 'libinput' for 'Logitech USB Keyboard Consumer Control'
[    65.632] (**) Logitech USB Keyboard Consumer Control: always reports core events
[    65.632] (**) Option "Device" "/dev/input/event3"
[    65.633] (**) Option "_source" "server/udev"
[    65.637] (II) event3  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    65.637] (II) event3  - Logitech USB Keyboard Consumer Control: device is a keyboard
[    65.637] (II) event3  - Logitech USB Keyboard Consumer Control: device removed
[    65.720] (**) Option "config_info" "udev:/sys/devices/platform/fd800000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C31C.0003/input/input3/event3"
[    65.720] (II) XINPUT: Adding extended input device "Logitech USB Keyboard Consumer Control" (type: KEYBOARD, id 9)
[    65.720] (**) Option "xkb_layout" "us"
[    65.720] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    65.725] (II) event3  - Logitech USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[    65.725] (II) event3  - Logitech USB Keyboard Consumer Control: device is a keyboard
[    80.917] (II) modeset(0): EDID vendor "SAM", prod id 3927
[    80.918] (II) modeset(0): Using EDID range info for horizontal sync
[    80.918] (II) modeset(0): Using EDID range info for vertical refresh
[    80.918] (II) modeset(0): Printing DDC gathered Modelines:
[    80.918] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[    80.918] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[    80.918] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    80.918] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    80.918] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    80.918] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    80.918] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    80.918] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    80.918] (II) modeset(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    80.918] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    80.919] (II) modeset(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    80.919] (II) modeset(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    80.919] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    80.919] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    80.919] (II) modeset(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    80.919] (II) modeset(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    80.919] (II) modeset(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    80.919] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    80.919] (II) modeset(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    80.919] (II) modeset(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    80.919] (II) modeset(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    80.919] (II) modeset(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    80.919] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[    80.919] (II) modeset(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[    80.919] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    80.919] (II) modeset(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[    80.920] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[    80.921] (--) modeset(0): HDMI max TMDS frequency 250000KHz
your monitor is not detected
donation   irradium
that particular monitor worked with your 4.19 build
(12-06-2021, 08:12 AM)dieselnutjob Wrote: that particular monitor worked with your 4.19 build
try to reconnect physically HDMI after booting
donation   irradium
The mainline vop2 patchset only works at 1080p right now as far as I can tell, so your monitor needs to be able to handle a 1080p mode.
Plebian GNU/Linux
  USB on Quartz64 Zero litbulb 1 1,721 07-22-2026, 02:04 PM
Last Post: MichaIng
  DietPi OS for Quartz64 MichaIng 48 56,176 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 17,774 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,238 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 176,685 03-23-2025, 01:10 AM
Last Post: balbes150
  quartz64-a - on-board SATA port problems manning 2 5,381 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 4,292 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 10,683 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 3,928 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 55,532 03-17-2022, 06:29 AM
