Mobian kernel upgrade
Is mobian updating the 5.10 kernel with new patches or do we need to update/upgrade manually?
I have a bookworm install
There is information on upgrading to kernel 5.13 in the bookworm thread. (You'll want to be on the bookworm release if not already there. EDIT: I see you've already done that!) Installing the kernel amounts to:
apt search linux-image | grep sunxi  # List available kernels
apt install linux-image-5.13-sunxi64  # Install kernel
A wrinkle to this is that apparently with this kernel the screen brightness will be set to zero unless you otherwise set it during boot, so you'll want to do that first and make sure it's working before booting the 5.13 kernel. (Also to be on the safe side in case you get a black screen make sure you have another means of getting into the phone like ssh enabled.)
To set brightness at boot time I enabled the old-school /etc/rc.local file:
https://www.troublenow.org/752/debian-10-add-rc-local/
Then in /etc/rc.local I put the following command (higher number is more brightness and vice versa, I don't know what the max is):
echo 600 > /sys/class/backlight/backlight/brightness
(11-10-2021, 03:23 AM)user641 Wrote: Is mobian updating the 5.10 kernel with new patches or do we need to update/upgrade manually?
Looks to me that the latest 5.10 via update/upgrade is 5.10.56. (You can also install 5.14.8 via apt install.)
I think kernel 5.15 will probably come soon in Mobian. I would from my side wait until it's there as it's a long term supported one
(11-10-2021, 09:18 AM)vongillus Wrote: I think kernel 5.15 will probably come soon in Mobian. I would from my side wait until it's there as it's a long term supported one
I think this is the best approach for me, as I use as daily drive. Just checked I am running 5.10.56.
  Mobian MMS/SMS text problem bcnaz 16 39,666 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,841 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 69,703 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 73,991 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,437 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 348,134 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,099 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,303 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,057 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,733 04-29-2025, 02:10 PM
Last Post: mdk
