11-10-2021, 03:23 AM
Is mobian updating the 5.10 kernel with new patches or do we need to update/upgrade manually?
I have a bookworm install
Mobian kernel upgrade
11-10-2021, 08:33 AM
(This post was last modified: 11-10-2021, 08:57 AM by Zebulon Walton.)
There is information on upgrading to kernel 5.13 in the bookworm thread. (You'll want to be on the bookworm release if not already there. EDIT: I see you've already done that!) Installing the kernel amounts to:
apt search linux-image | grep sunxi # List available kernels apt install linux-image-5.13-sunxi64 # Install kernel A wrinkle to this is that apparently with this kernel the screen brightness will be set to zero unless you otherwise set it during boot, so you'll want to do that first and make sure it's working before booting the 5.13 kernel. (Also to be on the safe side in case you get a black screen make sure you have another means of getting into the phone like ssh enabled.) To set brightness at boot time I enabled the old-school /etc/rc.local file: https://www.troublenow.org/752/debian-10-add-rc-local/ Then in /etc/rc.local I put the following command (higher number is more brightness and vice versa, I don't know what the max is): echo 600 > /sys/class/backlight/backlight/brightness
11-10-2021, 09:14 AM
(This post was last modified: 11-10-2021, 09:15 AM by dukla2000.
Edit Reason: typo
(11-10-2021, 03:23 AM)user641 Wrote: Is mobian updating the 5.10 kernel with new patches or do we need to update/upgrade manually? Looks to me that the latest 5.10 via update/upgrade is 5.10.56. (You can also install 5.14.8 via apt install.)
11-10-2021, 09:18 AM
I think kernel 5.15 will probably come soon in Mobian. I would from my side wait until it's there as it's a long term supported one
| Mobian MMS/SMS text problem | bcnaz | 16 | 39,680 |
06-23-2026, 06:53 AM Last Post: mehdy |
| Mobian image for the PinePhone | Korfou | 2 | 1,844 |
04-27-2026, 09:57 AM Last Post: Korfou |
| bookworm vs trixie discussion for mobian in pinephone regular. | zetabeta | 80 | 69,735 |
12-24-2025, 12:11 AM Last Post: Kevin Kofler |
| cryptocurrency on mobian/pinephone | biketool | 33 | 74,020 |
10-08-2025, 06:21 AM Last Post: biketool |
| XLibre for Mobian | Hiraghm | 0 | 3,438 |
06-29-2025, 12:38 PM Last Post: Hiraghm |
| Axolotl on PinePhone / Mobian | arno_nuehm | 223 | 348,225 |
06-25-2025, 01:19 PM Last Post: anonymous |
| VoIP account on mobian dialer | j_s | 0 | 3,101 |
06-15-2025, 04:19 PM Last Post: j_s |
| Mobian Pinephone Notification LED | biketool | 2 | 4,306 |
06-07-2025, 03:19 PM Last Post: KC9UDX |
| Vivaldi Web browser nearly native for Mobian | biketool | 3 | 5,060 |
05-06-2025, 02:19 AM Last Post: biketool |
| mobian calamares fail | merom | 2 | 4,733 |
04-29-2025, 02:10 PM Last Post: mdk |
