Manual to Compile Android for PINE46
Anyone,
Could please provide the steps to compile an Android image for PINE64. I would like to start working in the latest Android image, specially targeting the AndroidTV build for the PINE64.
This thread could be used to aggregate the steps-by-steps later.
Provisioning to add possible steps here later, so no one needs to hunt multiple pages of messages.
Download latest Android SDK (Android MM 6.0) from here: http://wiki.pine64.org/index.php/Pine_A6...ndroid_SDK
Once in the source directory:
(Its very useful to use ccache and -jobs option to speed up a lot the compiling procedure)
$ export USE_CCACHE=1
$ export CCACHE_DIR=/path/of/.ccache
$ prebuilts/misc/linux-x86/ccache/ccache -M 50G
$ source build/envsetup.sh
$ lunch tulip_p1-eng
$ make -jN
Replace /path/of/.ccache with your preferred directory
Replace N with the number of your CPU cores.
But, at this point I have a question too:
How to flash the MicroSD using dd? I can't find any info in the wiki.
I mean, we should have a proper partition layout before to flash generated image files.
Is anyone working on a dedicated media-image like Openelec ?
(05-22-2016, 08:34 AM)NGC6691 Wrote: Download latest Android SDK (Android MM 6.0) from here: http://wiki.pine64.org/index.php/Pine_A6...ndroid_SDK
Thanks for the quick reply, why tulip_p1-eng ?
did you created the pine64 or this is a copy from another device, to use as baseline  ?
(05-22-2016, 09:17 AM)Bloodyraw Wrote: Is anyone working on a dedicated media-image like Openelec ?
I take that you mean linux based ? We would need the mali binaries for that to make sense.
tulip_p1 is the device codename of PINE64.
I had to modify the file build/core/combo/mac_version.mk
How can I upload you, or anyone with this changes ? where is the official github tree ?
Also I'm getting this error:
Checking build tools versions...
You are attempting to build with the incorrect version
of java.
Your version is: java version "1.8.0_60" Java™ SE Runtime Environment (build 1.8.0_60-b27) Java HotSpot™ 64-Bit Server VM (build 25.60-b23, mixed mode).
The required version is: "1.7.x"
Please follow the machine setup instructions at
https://source.android.com/source/initializing.html
build/core/main.mk:171: *** stop. Stop.
\e[0;31m#### make failed to build some targets (16 seconds) ####\e[00m
Android 6 and M where suppose to compile on OpenJDK or JDK 8
(05-23-2016, 11:44 AM)lvcargnini Wrote: I had to modify the file build/core/combo/mac_version.mk
of java.
It seems we need to add teh following :
export EXPERIMENTAL_USE_JAVA8=1
I'm trying to set this variable without too many success so far.
When I try to compile it, I get an error
No private recovery resources for TARGET_DEVICE tulip_p1-eng
make: *** No rule to make target 'external/wpa_supplicant_8/wpa_supplicant/src/drivers/drivers.mk'. Stop.
#### make failed to build some targets (08:39 (mm:ss)) ####
I tried to reinstall ubuntu, the same issue
How can I solve it?
I use Ubuntu 16.04 and openjdk-7
@lvcargnini: I suggest you to downgrade to java 7, Android 6 isn't ready yet to be compiled with java 8 by default.
AFAIK there isn't any official github tree.
(05-24-2016, 02:50 AM)IlyaM Wrote: When I try to compile it, I get an error
How can I solve it?
Take a look in external/wpa_supplicant_8/wpa_supplicant, there must be a symlink named src pointing to ../src.
  Need help compiling android for pine a64 + YeeticusMaximus22 1 631 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 547,852 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 44,092 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 28,098 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,071 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,355 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,133 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,792 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 366,373 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,522 02-26-2019, 11:58 AM
Last Post: Twistedx
