Installed Sim phone not working
Modem status does not show carrier
Network - Unknown
Signal - 41%
Network Status Not registered
Own Number - ***-***-****  Is Correct
Is there a patch or anything to get this modem to work correctly?  Still new and learning everyday.
Thanks,
kmk
More info needed - which carrier in which country, and does their local cell use frequencies supported by the PinePhone?
(10-24-2021, 03:56 AM)wibble Wrote: More info needed - which carrier in which country, and does their local cell use frequencies supported by the PinePhone?
Hey Brother,
United States, T-mobile.  yes supported too.
Kmk
1) is your O.S. updated ?
2) with the Pinephone, it is quite simple to flash and run an micro-sd card, quick way to see if the 'installed' O.S. is faulty.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,649 07-03-2024, 08:38 PM
  New phone, KDE desktop settings reset on reboot zzb0 2 5,995 10-15-2023, 10:19 PM
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 2,827 09-24-2023, 05:18 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 15,544 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  New issue with phone calls kmsgli 13 17,548 08-15-2022, 01:45 PM
Last Post: Gon
  Keyboard case stopped working on pacman update rotwang 5 7,460 05-07-2022, 09:17 PM
Last Post: rotwang
  Calls & SMS stopped working Schugy 3 5,005 12-28-2021, 05:00 AM
Last Post: Schugy
  Phone goes to sleep whilst audio playing new2pinephone 0 2,620 12-22-2021, 05:50 PM
Last Post: new2pinephone
  No incoming SMS. Outgoing SMS, calls and data working. HardwarePunk 3 6,448 11-20-2021, 12:53 AM
Last Post: HardwarePunk
  Why is sshd installed/listening by default insidetrip101 0 2,331 11-14-2021, 10:29 AM
Last Post: insidetrip101
