GloDroid (Android-13)
#91
(04-06-2021, 08:23 AM)layton-dev Wrote: Hi ! I'm currently using Glodroid v0.5.1 on the Pinephone, I'm wondering if TrustyOS is supported on this device ?
I'd guess that would need the a64's hardware trustzone feature to be implemented in software - which it probably isn't at the moment.
I see, thank you for your reply Smile !
GloDroid 0.6.1 has been released recently: https://github.com/GloDroid/glodroid_man...tag/v0.6.1
I hope to find the time to make a quick install guide video for the SD card install next week to draw some attention to the project.
Edit: Here it is!
Wink
Coincidentally, I also did a tutorial on installing GloDroid almost at the same time as linmob. Wink
Here is the link:
https://www.youtube.com/watch?v=uwgUVXuP18E
Just wanted to chime in; I set up GloDroid on an SD card for my pinephone last night, and it feels like so much progress has been made. I haven't put a SIM card in it to test phone calls or data usage, but every-day usage like browsing the internet on Firefox or installing whatever from F-Droid feels so natural, and it just works!
It's amazing how well this device runs with software that was made for phones. As excited as I am for other prospects like Manjaro+Plasma Mobile, this is far and away the most pleasant to use experience on my pinephone right now in 2021.
It's actually so smooth I gotta wonder; Is Glodroid using full hardware acceleration with the mali400 GPU in the pinephone?
(07-03-2021, 10:56 AM)gamerminstrel Wrote: Just wanted to chime in; I set up GloDroid on an SD card for my pinephone last night, and it feels like so much progress has been made. I haven't put a SIM card in it to test phone calls or data usage, but every-day usage like browsing the internet on Firefox or installing whatever from F-Droid feels so natural, and it just works!
It feels buttery smooth sometimes, but when I tried installing a camera application, the cameras will not work. Also, I heard phone features do not work yet.
Hello all,
I Installed the 0.6.1 version into eMMC using the guide in (https://youtu.be/WbqzMXsnEEA) and it runs perfectly smooth. Going through the menus is easy and fast, amazing. Installed Firefox works very well, use F-droid to install anything, Newpipe needs a second to start and is fine, sound is good but low volume, screen is very stable all around.
A few comments:
- Missing phone operation (this is important Smile ;
- Wifi has glitches (^goes off and to reconnect switching off and on again is necessary);
- BT works (was able to transfer a file between androids);
- Name of device goes back to stock after reboot;
- No Headphones;
- No lockscreen (pin security or password);
- No camera;
- No GPS?;
- VLC could not play a 1080 video downloaded using Newpipe.
- Build update through flash only(is this correct?;
Very good work, keep it up!!
This is a super small thing I noticed, but it feels like the built-in speaker is not being used to its full potential. Yea its not a great speaker, but I can barely hear audio at max volume. Wouldn't even be an issue if I could use the headphone jack.
(07-09-2020, 12:22 PM)rsglobal Wrote: GloDroid (AOSP for the world's most accessible development platforms)
https://github.com/GloDroid/glodroid_manifest
Releases (Prebuilt images are available under assets drop-down list):
https://github.com/GloDroid/glodroid_manifest/releases
Unofficial Youtube overview:
How to install Android 11 on PinePhone:
Android 11 on PinePhone, customizing and installing apps:
https://www.youtube.com/watch?v=w9Oqlwb2...e=youtu.be
Does anyone know what the Authentication password for it?
Thank You
Chris
Is there a way like OTA updates to update GloDroid/Android itself without turning the device off and reflashing the entire system? It feels a bit less than ideal to basically factory reset to see how the latest update works.
  GloDroid (Android-14) GaryM 1 6,889 04-17-2024, 08:39 AM
Last Post: GaryM
Tongue Android Auto on Pinephone via Waydroid: a pipe dream? slondr 1 5,884 11-06-2022, 01:46 PM
Last Post: wibble
  difference between android and linux? vanja 3 6,368 09-16-2022, 07:43 PM
Last Post: TRS-80
  Android and Google Play Store on a PinePhone? Solra Bizna 22 62,969 11-01-2021, 07:11 AM
Last Post: digitalmouse
  Easiest way to use Android applications on Pinephone esud 4 16,589 06-21-2021, 04:52 AM
Last Post: vanja
  Remote connection from Linux Mobile to unrooted Android? (surely very useful?!) 4w7gvrvsjcyvd 0 3,577 01-30-2021, 06:48 PM
Last Post: 4w7gvrvsjcyvd
  pine phone came with android? andrewiassur 1 5,554 04-11-2020, 02:06 PM
Last Post: fire219
