Wrong FN keys after keyboard FW update
Bug
I performed keyboard firmware update for my Pinebook Pro ANSI as described on Pine64 wiki (just performed on Manjaro) and noticed few things.
- during update there were few messages "device not found" but firmware update seems to completed successfully
- after update some keys are behaving differently from their labels
  - Fn + F9 - labeled as Print Screen, behaves as NumLK
  - Fn + F10 - labeled as NumLK, behaves as ScrLK
  - Fn + F11 - labeled as ScrLK, behaves as Pause
  - Fn + F12 - labeled as Pause, behaves as NumLK
The rest of the keyboard is working propperly as it should. Before the update everything worked propperly so I assume this is caused by firmware update itself. Is there any way to narrow these things? I am affraid of messing things up and ending with non-working keyboard.
Thanks in advance!
I don’t think it’s the firmware because those keys mapped correctly before I blew away my old Manjaro dist and installed newest repo version and also work with latest. I flashed firmware/kb/tpad w/iso using fork Dragan Simic’s see pine64 wiki pinebook pro firmware section.
It could be something with the incorrect keyboard layout choice in system settings. I selected default keyboard layout for ansi even though my keyboard is iso I just need to know the keys by memory for a few special characters. Oh and I’m US English-UTF-8
Sent from my iPhone using Tapatalk
Ne quid nimis
I don't think this has to do with Manjaro as it was reinstalled in september (I think). The only thing changed from then is my migration to SwayWM.
The keyboard behaved the same in Plasma X11 and Sway.
My output from setxkbmap -query
rules:      evdev
model:      pc105
layout:     us
I am using Jack Humbert's fork but that should be OK. I think I solved my problem with step-3 - using revised firmware data. For some reason I overlooked that. Now everything looks to behave correctly.
  Keyboard issue j0rs 3 5,508 01-20-2025, 07:03 AM
Question Pinebook pro dead / keyboard issue? / Troubleshooting Mengalef 2 4,813 12-05-2024, 04:16 PM
  Keyboard unresponsive after some idle time in uboot Trinatriumcitrat 1 4,063 11-25-2024, 03:42 PM
  Locked out after update Shylocked 5 5,567 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,475 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,159 09-16-2023, 09:41 AM
Last Post: jd50i
  Dead Pinebook Pro Keyboard Keys calinb 2 4,417 09-02-2023, 12:31 PM
Last Post: calinb
  power on Pinebook Pro mainboard without keyboard? papable 0 2,986 07-20-2023, 11:06 PM
Last Post: papable
  PineBook Pro - Did I buy the wrong computer? astral 8 11,506 05-04-2023, 05:47 AM
Last Post: korreckj328
  Metis package can't update Mangustis 1 4,005 02-22-2023, 03:23 PM
Last Post: robocone
