How did you get data working on PureTalk?
I have a PureTalk sim in the phone. It gets calls and texts, but data doesn't work. I keep getting texts warning me that the 3G is going away; I suspect that is connected to no data.
Settings shows, under Modem Details:
Carrier PureTalk
Network type LTE
Signal strength 44%
Network Status Registered
Under access points:
Access point name att.mvno
Running Mobian Bookworm on the eMMC.
Any ideas on how to get data working?
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
(09-25-2021, 10:21 AM)nelstomlinson Wrote: I have a PureTalk sim in the phone. It gets calls and texts, but data doesn't work. I keep getting texts warning me that the 3G is going away; I suspect that is connected to no data.
Carrier PureTalk
Network type LTE
Signal strength 44%
That is a common mistake when "Setting Up"
It should be   Name : Pure Talk  and
 APN : RESELLER
and if you want to use the 'Hot Spot'
You simply call support and ask for the  Hot Spot option to be 'turned on'
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(09-25-2021, 12:02 PM)bcnaz Wrote: ****
 APN : RESELLER
APN RESELLER worked.
Now the Pure Talk SIM is in my old Blackberry, since the speaker died and I can't use it any more, but that worked in the Blackberry, and would probably work in the PP.
Now I have to call GCI and figure out how to get data working on their network, since I'll be using the PP as my daily driver, ready or not.
  4G VoLTE calls confirmed working with carrier x dcinoz 17 40,040 10-07-2025, 11:05 AM
Last Post: baptx
  MMS sending stopped working amindfv 7 8,476 05-04-2025, 01:36 PM
Last Post: zetabeta
  My new phone stopped working. gunnygee 3 5,017 12-12-2024, 01:21 PM
  how to backup user data? Uturn 1 2,831 08-30-2023, 05:23 AM
  New Zealand network providers mobile data Linux2thabone 3 7,054 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 9,058 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  PureTalk work with Pinephone? car46999 6 10,231 01-30-2023, 12:05 AM
Last Post: car46999
  cell data and MMS on AT+T prepaid ossands 2 4,696 10-13-2022, 07:28 AM
Last Post: ossands
  Instructions to get pinephone working on USA carrier omarcomputing 1 4,510 10-08-2022, 04:45 PM
Last Post: treebeard
  JumpDrive isn't working phytocube 2 5,188 06-05-2022, 03:22 PM
Last Post: phytocube
