| Welcome, Guest |
| Latest Threads |
PostmarketOS renamed to N...
Last Post: NorrisFByrd
6 hours ago
PBP does not start from p...
Forum: Linux on Pinebook Pro
6 hours ago
» Replies: 22
PinePhone Game Thread
Yesterday, 12:51 AM
» Replies: 32
Pinephone visibly losing ...
Yesterday, 12:50 AM
» Replies: 12
OpenBSD 7.6
Forum: BSD on Pinebook Pro
Last Post: zer0sig
11-25-2026, 10:00 PM
» Replies: 2
Choosing a small SBC for ...
11-25-2026, 12:25 AM
Has anyone tried FygoOS o...
Forum: RockPro64 Projects, Ideas and Tutorials
Last Post: yeaishere
11-24-2026, 09:26 PM
» Replies: 0
Looking for a truck batte...
11-24-2026, 02:12 AM
» Replies: 2
rAudio for Rock64 V2/Pine...
Forum: Linux on Rock64
Last Post: shinzuka
11-24-2026, 01:20 AM
» Replies: 15
Looking for testers: nati...
Forum: Game Station Emulation
Last Post: goodoldgamesdev
11-23-2026, 01:38 PM
» Replies: 2
| Mounting the IR Receiver on the PineA64 for use with OpenHour Remote |
Posted by: MarkHaysHarris777 - 08-11-2016, 03:37 PM - Forum: IR Receiver
- Replies (7)
Prior to mounting the VS1838 or HX1838 IR receiver on the PineA64 SBC, it is helpful to mod the receiver; this does require some minimal (but easy) soldering skills. What is at issue is that the leads on the IR receiver are too thin to make good contact with the female header socket on the PineA64 board (found between the system LED solder pads and the audio jack just to the right of the audio jack looking at the usb port side of the board).
The pic above shows the mod; the un-modded receiver is in the plastic bag. I have cut the leads on the receiver and soldered it to three male header pins (these are designed to fit the socket on the PineA64 SoC board. The technique is straight-forward; tin the leads on both the receiver and the header pins... tack solder the receiver to one header pin (leave them on the row of pins for easier handling). Then, solder the other two leads, returning to the tack point and re-solder the first lead. Then to finish up, cut the modded IR receiver from the row of header pins.
I have placed the modded IR receiver in the PineA64 board socket in the pic above. My board has the system programmable LED soldered in place... the IR receiver plugs into the female socket with the bubble and cross facing outward : pinouts ( OUT, GND, VCC). The IR mod makes for a good electrical fit with the socket.
The pic above is the OpenHour learning remote, which works with the IR receiver provided (VS1838, HX1838). To test the remote you can watch evtest while sending control codes to the IR receiver from the OpenHour remote. Also, if you open a terminal you can see the remote signals as characters typed on the screen. The digits will be one less than displayed... the down arrow is the backspace, and several of the function buttons are alpha characters. To use the remote with gnu+linux apps it is only necessary to map the codes to functions the way you might map any media key on a standard keyboard.
edit: I will be posting the data sheet as soon as I confirm the type and model of the IR receiver as shipped.
| Power Off / Reset Buttons - DietPi |
Posted by: casmiguefl - 08-11-2016, 03:32 PM - Forum: POT modules
- Replies (4)
Hi!
My pine arrived a couple days ago. I'm loving this little beast.
I have a couple trigger buttons laying around and I'd like to use one for the power off and other for the reset but I have no idea if the system is actively listening to the circuit of both these buttons.
I tried them on and nothing. Any tips?
Currently running DietPi as the OS.
Thanks!
| Power-on pine by remote |
Posted by: kleintvra - 08-11-2016, 02:38 PM - Forum: General Discussion on PINE A64(+)
- Replies (1)
Is there anyway to power pine by using the airmouse?
As far as i checked the airmouse power button send the signal on the IR and not on the wifi.
I've tried to connect an IR receiver (HX1838), but didn't have any luck powering-on pine.
| Debian do not remember my time setting. |
Posted by: Wolfenstein - 08-11-2016, 02:13 PM - Forum: Debian
- Replies (9)
When I start my Pine the time is wrong. So I click the clock in the upper right corner and set it right.
The next time I start the Pine the time is wrong again.
I am in CET and it is set to CET and it is till 2 hours off every time I start it.
| Change Android boot logo? |
Posted by: ipsw - 08-11-2016, 02:07 PM - Forum: Android on Pine A64(+)
- Replies (5)
Hello, anyone know if it's possible to change the boot logo of the Android 5.1.1? I use the pine on my car so I would like to have the brand logo of my car instead of the PINE64 logo
Thank you !
| SD card burn img size problems |
Posted by: stephen0205 - 08-11-2016, 07:34 AM - Forum: Getting Started
- Replies (17)
Ok so i have been using the original android without update on my micro sd card on my tv and running kodi for a while when i saw there was an update i went to install and nothing happened status 7 error during reboot stage so no update.
Though i can set kodi back up screw it, fired it on the pc booted up win32disk imger which i used before, format and went to use the 64gb img, i have a sandisk ultra 64gb card. Kept getting img to large for target disk. WTF. Tried a few other tools, rufus included and same error
what the heck am i doing wrong i was literally pulling my hair out with this one, eventually resorting to flashing the 32gb version of the rom. Im now missing half my storage.
suggestions fellas
