» Members: 30,272
» Latest member: PrinterSolvedTeam
» Forum threads: 16,394
» Forum posts: 117,653
Satellite antenna
Forum: Community and Events
Yesterday, 02:46 PM
» Replies: 2
Irradium (based on crux l...
Forum: Linux on Pinebook
10-25-2026, 04:11 AM
» Replies: 5
Booting Issues
Forum: PineNote Software
Last Post: vlagged
10-23-2026, 12:14 PM
» Replies: 25
Alpha One - no connectivi...
Forum: Getting Started
Last Post: Dabdarklighter
10-22-2026, 03:51 PM
Article: The Advantages o...
Last Post: zetabeta
10-20-2026, 02:38 PM
» Replies: 2
Star64 Irradium (based on...
10-19-2026, 12:27 PM
» Replies: 22
StarPro64 Irradium (based...
10-19-2026, 10:01 AM
» Replies: 25
Article: Will Linux phone...
Last Post: amosbatto
10-19-2026, 09:52 AM
» Replies: 11
Login issues
Forum: PineTab Hardware
Last Post: Corkonian
10-17-2026, 02:34 AM
» Replies: 2
Rii mini 4 keyboard and t...
Forum: PinePhone Accessories
Last Post: Flymoon
10-15-2026, 08:04 AM
» Replies: 3
  Good advances in Panfrost Open Source driver
Posted by: tuxd3v - 10-21-2018, 09:49 PM - Forum: General Discussion on ROCKPRO64 - Replies (1)
Alyssa have been working like mad on Panfrost Open Source driver..
They used a RK3399 ARM laptop...
They were able to run some wayland applications, and performance checks on glmark2-es2
This drivers adds support for:
Midgard (Mali Txxx)
Bifrost (Mali Gxx)
His cronics about Xorg meeting..
https://rosenzweig.io/blog/a-panfrostian-october.html
  MMC and SD?
Posted by: ab1jx - 10-21-2018, 05:11 PM - Forum: Linux on Rock64 - Replies (12)
Is there any reason you can't install an OS (Debian please) on the MMC and keep the SD for data that you might want to plug into another machine?  Don't know if they're both mapped to the same address or something.  Maybe it's been answered before.
I would expect to do a dmesg when booted from the MMC and see a new device had been attached then be able to mount the partition(s) on it manually.  (Oh, that's right, it isn't kosher to hotplug an SD card, but like a USB stick or drive or SD in a USB reader.)  Or maybe boot from the SD as an alternative to what's on the MMC.  I've never had an MMC.
  Linux not working properly (noobie)
Posted by: jannerman - 10-21-2018, 10:46 AM - Forum: Linux on RockPro64 - Replies (2)
First of all this is my first sbc and I might not doing somethings properly.tas fan from pine store, 16GB eMMC in NAS Metal Case.
I used "LXDE Desktop aarch64 [microSD / eMMC Boot] [0.7.9]"
1) How do you control the fan?
2) Is there any HW Acceleration? Youtube, daily motion are playing with 20-25 fps top.
I played with some kernels but didn't see any difference (only in sound, the known bug).
3) WiFi module doesn't work. Is this normal? I saw something in changelog. I also upgrade to 0.7.10 by changing apt lists and didn't see any difference.
4) Can't get the SATA PCIe work in graphic environment.
If I press ctrl+alt+f1 and login, I can see the PCIe card (lspci works), I can use parted, format the drive and mount it succesfully.
If I try to use LXDE everything freezes.
If I don't do anything with the drive, even lspci freezes the rpro64.
So my HDD is useless in desktop mode.
Is anyone experience the same problems?
Is there any Linux distribution that works without problems? Any kernel suggestion?
  PCIe Inconsistency Problems
Posted by: jja2000 - 10-21-2018, 06:39 AM - Forum: Linux on RockPro64 - Replies (18)
I've posted this in another thread:
(10-20-2018, 05:36 AM)jja2000 Wrote:
(10-15-2018, 05:28 AM)jja2000 Wrote: I've been having trouble getting my Pine bought PCIe SATA card to work aswell.
It used to show up before but then totally disappear. The HDD spins up but does not show up in lsblk or in dmesg. There's no LED burning on the card. The HDD works aswell.
Doing a dmesg | grep pci gives me this:
rock64@rockpro64:~$ dmesg | grep pci [    0.498071] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0) [    0.498129] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree [    0.498167] vcc3v3_pcie: supplied by dc_12v [    0.498232] vcc3v3_pcie: 3300 mV [    0.498386] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 3300000uV [    1.177078] ehci-pci: EHCI PCI platform driver [    2.656712] vcc3v3_pcie: disabling [    3.114214] phy phy-pcie-phy.9: Looking up phy-supply from device tree [    3.114218] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed [    3.292837] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep [    3.292852] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup [    3.292902] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0) [    3.293278] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree [    3.293470] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree [    3.293483] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed [    3.293518] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [    3.302175] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree [    3.302195] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed [    3.302230] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [    3.313324] rockchip-pcie f8000000.pcie: invalid power supply [    3.820353] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [    3.830861] rockchip-pcie: probe of f8000000.pcie failed with error -110
Okay so I installed mainline and I get a similar error:
rock64@rockpro64:~$ dmesg | grep pci [    1.709157] vcc3v3_pcie: supplied by dc_12v [    2.994902] ehci-pci: EHCI PCI platform driver [    3.051118] ohci-pci: OHCI PCI platform driver [    3.468181] vcc3v3_pcie: disabling [    6.753355] rockchip-pcie f8000000.pcie: no vpcie12v regulator found [    6.753416] rockchip-pcie f8000000.pcie: Linked as a consumer to regulator.3 [    6.753431] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [    6.753441] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [    7.308970] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [    7.309707] rockchip-pcie f8000000.pcie: Dropping the link to regulator.3 [    7.309778] rockchip-pcie: probe of f8000000.pcie failed with error -110
But it happens a lot less consistently, mostly reboots and a bit of reseating of the cables makes it function again.
When it does work and I try to access the harddrive (either by mounting or by opening a partition manager via ssh) the board (presumeably, because I have no display output on Mainline and no way to read the GPIO pins for serial) kernel panics.
It kinda sucks that I can't use this device as intended. Anyone have a suggestion to make this work?
  Install Playstore on Android 8.1.0
Posted by: Domo - 10-20-2018, 08:26 PM - Forum: Android on RockPro64 - Replies (14)
How to install PlayStore on Android 8.1.0
The zip with all needed files : https://drive.google.com/file/d/1upg2H9uCBhKEgU1is19LNmKEqpwB9KE6/view?usp=sharing
IMPORTANT : This file are not the same as for Android 7.1.2
Activate developer mode and get a root shell:
./adb device
./adb root
./adb remount
./adb push playstore.apk /system/priv-app/
./adb push playservices.apk /system/priv-app/
./adb push gsf.apk /system/priv-app/
./adb install -r gsf.apk
./adb install -r playservices.apk
./adb install -r playstore.apk
./adb push libAppDataSearch.so /system/lib/
./adb push libconscrypt_gmscore_jni.so /system/lib/
./adb push libgcastv2_base.so /system/lib/
./adb push libgcastv2_support.so /system/lib/
./adb push libgmscore.so /system/lib/
./adb push libgoogle-ocrclient-v3.so /system/lib/
./adb push libjgcastservice.so /system/lib/
./adb push libjingle_peerconnection_so.so /system/lib/
./adb push libleveldbjni.so /system/lib/
./adb push libnative.so /system/lib/
./adb push libsslwrapper_jni.so /system/lib/
./adb push libvcdiffjni.so /system/lib/
./adb push libwearable-selector.so /system/lib/
./adb push libWhisper.so /system/lib/
Then reboot and go to the android settings, apps and give all the permissions to the apks installed.
The following commands should also be executed on the RockPro64 to prevent occasional Google Play Services errors: So run the beginning commands and get into adb shell and run these commands:
./adb shell
pm grant com.google.android.gms android.permission.ACCESS_COARSE_LOCATION
pm grant com.google.android.gms android.permission.ACCESS_FINE_LOCATION
Reboot again.
Finish
  Install Playstore on Android 7.1.2
Posted by: Domo - 10-20-2018, 12:49 PM - Forum: Android on RockPro64 - Replies (6)
The zip with all needed files : https://drive.google.com/file/d/1YAMZF0J...mDRpP/view
./adb device
./adb root
./adb remount
Then reboot and go to the android settings, apps and give all the permissions to the apks installed. Start Play Store, do not input anything, just exit.
./adb shell
Reboot again.
Finish
  USB Wireless
Posted by: y0sh - 10-20-2018, 07:07 AM - Forum: Linux on RockPro64 - Replies (8)
Are you able to add a usb wireless? I have a couple different types and they all work with linux but nothing is working here. I was wondering if anyone has gotten a usb wireless to work and what they had to do.
  Is it "late October" yet?
Posted by: jschall - 10-20-2018, 06:31 AM - Forum: General Discussion on Pinebook - Replies (30)
Like many of you, I'm looking forward to receiving my Pinebook 11.6". They were supposed to ship "in late October".
So, I'm just wondering if anybody has received a notice that theirs has shipped?
  Update Kernel
Posted by: y0sh - 10-19-2018, 07:05 PM - Forum: Linux on RockPro64 - Replies (1)
I just install the LXDE desktop and i noticed the kernel i was running is Linux rockpro64 4.4.132-1083-rockchip-ayufan-gfd3f12ca5fae. I was wondering what would be a good kernel i should upgrade to or just stay with what i have.
  SOPINE Hardware Info
Posted by: ehrack - 10-19-2018, 05:05 PM - Forum: P64-LTS / SOPINE Hardware, Accessories and POT - Replies (2)
Hi there!
I'm brand new to the Pine 64 world, but I have tons of experience with the Raspberry Pi and linux.
I'm working on a project involving the SOPINE, but I'm really having trouble finding the info I need. One of the biggest issues I'm having is that I don't know what voltage rails I have to supply, and what I don't. Is there a data sheet somewhere that provides all this info, as well as info about what busses are where, and their specifications?
I've found the pinout, but that really doesn't tell the whole story.
Thanks in advance for your help!
-Connor
