Hardware Feature Suggestion for Quartz64: SPI Flash Hardware Write-Protect
Hardware Feature Suggestion: SPI Flash Hardware Write-Protect & Factory-Flashed Secure Boot
First of all, thank you for providing amazing open-source hardware to the community. I am a developer, privacy enthusiast, and independent researcher, and I would like to propose a simple yet high-value hardware revision for future batches of the Quartz64 or upcoming single-board computers. Currently, the board relies on DIP switches for boot priority, which is firmware-based and does not physically cut the power line for the SPI Flash write operations.
For users focused on sovereign security, physical containment, and preventing persistent firmware implants (rootkits), having a Hardware Write-Protect (WP# linked to GND via a physical Jumper or a Screw mechanism)—similar to the Chromebook write-protect screw—is crucial. Adding small exposed copper jumper pads (open pads) between Pin 3 (WP#) and Pin 4 (GND) on the PCB layout would allow advanced privacy users to bridge them and achieve true physical, air-gapped read-only isolation for the Tow-Boot/SPI flash.
Furthermore, for PINE64 boards that come with a pre-soldered SPI Flash from the factory, we strongly suggest shipping them with a clean, verified, and officially signed open-source bootloader (like Tow-Boot) pre-flashed out of the box. Many security-conscious buyers operate in highly compromised, untrusted, or heavily monitored network environments where flashing a clean image locally from scratch is incredibly risky or nearly impossible without immediate interception. Shipping the hardware with a factory-guaranteed clean bootloader would provide a secure and immutable root of trust immediately upon unboxing.
I highly recommend offering these as design standards in your upcoming revisions, or even as an optional manufacturing configuration toggle for a small extra fee. It would make PINE64 the ultimate choice for the global privacy and secure-boot developer community.
Looking forward to hearing your thoughts on this hardware implementation.
  Quartz64 Zero HDMI grobbs 2 3,285 05-03-2025, 11:04 AM
  Quartz64 Model A fan TeutonicTovarish 2 5,204 07-08-2024, 07:19 AM
Last Post: p1x3l3d
  gpio on Quartz64-a jyoung 3 5,792 05-24-2024, 06:41 AM
Last Post: Randomuser
  Is Quartz64 compatible with official 7'' Raspberry Pi display? maldus 1 4,996 02-05-2023, 09:28 AM
Last Post: CounterPillow
  SD card slot in Quartz64 model B psic4t 1 4,363 01-18-2023, 02:48 PM
Last Post: psic4t
  Quartz64 Model A - SATA & USB3 dml-pc 0 3,914 10-13-2022, 07:43 PM
Last Post: dml-pc
  Case for the Quartz64 Model B? kuleszdl 1 5,858 06-05-2022, 02:43 PM
  SPDIF TOSLink Adapter Hat for Quartz64 CounterPillow 2 7,725 10-09-2021, 08:46 AM
Last Post: Bullet64
