Creating custom PineTab modules?
Is it the strategy of Pine to allow others to create modules for the Pinetab? Or will only Pine offer these?
(05-29-2020, 05:02 PM)eaglecup Wrote: Is it the strategy of Pine to allow others to create modules for the Pinetab? Or will only Pine offer these?
You are welcome and encourage to create your own PineTab modules and just remember to share with community.
Great! I'm looking forward to details on how to go about this. Making it open source is indeed the goal.
Is there any more information about how to create custom expansion boards?
Are they currently PCI based?
What are the physical dimensions that an expansion board can be?
Could a USB stick theoretically fit inside that space? Or would that require a custom back cover?
(07-22-2020, 08:10 AM)eaglecup Wrote: Could a USB stick theoretically fit inside that space? Or would that require a custom back cover?
I don't know more than you, but I remember a SSD was mentioned, which even in M.2 format is bigger than a typical USB stick after you remove plastic case from it.
(07-22-2020, 08:10 AM)eaglecup Wrote: Is there any more information about how to create custom expansion boards?
The expansion board interface is USB 2.0 base. the normal USB stock not able to place inside PineTab due to height limitation (6mm). PineTab has a full type-A USB-2 port and you can plug in your USB stick there.
That doesn't address the physical dimensions question, which should include mounting points. Also electrical and mechanical specs for the connector. CAD models would be helpful.
Great to hear the internal expansion boards are USB 2.0 based. I suspect that will make things easier.
There are new files on the Wiki that go into the electronics, but there are unfortunately no design files with dimensions and such.
  Not able to power on PineTab anymore zkajdan 3 440 12-26-2023, 04:38 PM
Last Post: FortunateFowl
Question Will Pinetab 2 spare parts be available? vatin 6 1,556 12-09-2023, 01:31 AM
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 533 09-28-2023, 01:06 PM
Last Post: dynobang
  [Tutorial] How to overclock Pinetab 2 Darth-Apple 0 809 09-25-2023, 08:45 AM
Last Post: Darth-Apple
  External Reset button on PineTab V? michaelengel 0 529 09-18-2023, 06:31 AM
Last Post: michaelengel
  Pinetab 2 screen no longer coming on Fibonacci 9 2,963 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
  Pinetab completely bricked Saksmito 8 2,585 06-10-2023, 04:23 PM
Last Post: fxc
  What RISC-V chip will the PineTab-V use? msm 2 1,652 04-05-2023, 06:58 PM
Last Post: msm
Big Grin Howto: Pinetab Screen Replacements (+ Pictures) RTP 5 6,400 02-10-2022, 08:31 PM
Last Post: barray
  Offer: PineTab with keyboard firefox-58 3 4,694 09-27-2021, 12:36 PM
Last Post: stmguard
