Manjaro ARM Sway Profile
#21
So I did some final round for the upcoming 20.08 release on the weekend. Theming got much improved by now:
  • /etc/sway/themes/templates/ contains config templates for various files to be updated as soon as the theme changes
  • /etc/sway/config.d/ contains sway configs (exec_always), which takes the templates, replaces some placeholders with theme specific (color) values and moves them to the corresponding $HOME/.config folder
  • still there are two theme files matcha-green (default) and matcha-blue in /etc/sway/themes that hold the configuration for Matcha-Dark-sea and Matcha-Dark-azul themes respectively; configuration of the active theme via variable in /etc/sway/definitions
Next blog post will be about creating custom themes for the Sway profile....
As usual pre-release versions of the images are on a separate OSDN: https://osdn.net/projects/manjaro-arm-sway/storage/.
If no blocking issues will be found the next release will come along with 20.08!
Thanks for all your support!
  Manjaro Sway Theme Broken Eighty8 1 296 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,767 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 347 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,166 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,239 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 419 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 907 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,026 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,986 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 777 08-18-2023, 02:06 AM
Last Post: juliamenendez
