Anyone have CPU Speed widget on Manjaro 20.04?
I am loving Manjaro 20.04 on Pinebook Pro, really working well for me. I have had very few issues and most have been solved easily.
One issue that I have not figured out and have not been able to find in the forum with a search: I miss the CPU speed indicator/selector widget that was in the Debian install.
Has anyone got that to work under Manjaro?
Thanks, Tim
Lucko666
"Just say Angry to smilies.
(04-16-2020, 11:29 AM)tim2@timshome.com Wrote: I am loving Manjaro 20.04 on Pinebook Pro, really working well for me. I have had very few issues and most have been solved easily.
Thanks, Tim
Which DE are you using? If XFCE, you could probably use whichever widget the MATE install was using. (I'm guessing system-monitor) and there's several for KDE. Whichever you need/choose, you can likely find them available in the AUR. (You can turn it on in the preferences of pamac.)
(04-16-2020, 01:34 PM)tophneal Wrote:
(04-16-2020, 11:29 AM)tim2@timshome.com Wrote: I am using KDE, I looked in AUR and in repositories, didn't find it. Nor in "add widgets." Conky serving purpose but not as elegantly!
Thanks, Tim
Lucko666
Thanks, Tim
This plasmoid looks to be pretty close to the widget in the MATE taskbar.
https://store.kde.org/p/998908/
[quote pid='64265' dateline='1587070697']
I got this to work but I really don't think it replaces the Mate one. That one allowed you to control the scheme, like "conservative" "power saver" etc. This  one only shows speed.
[/quote]
Thanks for the suggestion, however. For now I can get detailed results using a module of Conky that I can install with Conky Manager, gives speed and load on all cores. Although it doesn't allow me to change the scheme, it shows that the computer is actively managing the CPU speed well.
[/quote]
Lucko666
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,700 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,416 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,515 02-19-2025, 12:49 PM
Last Post: zkajdan
  Manjaro Sway Theme Broken Eighty8 1 4,210 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,745 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 4,084 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,420 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,652 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 3,554 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,449 11-14-2023, 10:57 AM
Last Post: trifleneurotic
