Problem updating Manjaro
I'm trying to update my Manjaro install and I'm hitting errors trying to connect to "manjaro-arm.ericlay.online".  Any ideas?
Thanks.
I had a similar problem today trying to update a manjaro image I hadn't used in a few weeks. The 2020.02 release notes suggest manually updating the mirror list. After following those instructions I was able to download all the new packages, but the kernel package fails its signature check, so I still haven't been able to update.
I was able to solve the kernel signing issue by running
sudo pacman -Sy manjaro-arm-keyring
(03-19-2020, 02:31 PM)bceverly Wrote: Hi,
Thanks.
I think you're using older version of Manjaro image and this error is caused by change in our mirror repo structure.
Old mirrors are no longer active.
You will have to install the latest mirrors manually using the following command.
sudo pacman -U https://ftp-osl.osuosl.org/pub/manjaro-arm/repo/stable/core/aarch64/pacman-mirrorlist-20200225-1-any.pkg.tar.xz
sudo pacman-mirrors -b stable
sudo pacman-mirrors -g
sudo pacman -Syyuu
I hope this works and if it doesn't work then you need to flash the latest image which is 20.02.1 from official manjaro page.
Try the above and let me know.
Manjaro ARM Team.
  Manjaro Sway Theme Broken Eighty8 1 301 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,778 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 351 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,180 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,263 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 426 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 918 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,032 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,994 08-21-2023, 09:08 PM
  Help please, problem with xen domU guest on rockpro64 pine64 v2.1 mrc1965 1 1,194 08-21-2023, 09:05 PM
