Help please, problem with xen domU guest on rockpro64 pine64 v2.1
Hi all,
I'm facing two kind of problem trying to create a Xen guest domain on pine64.
I have successfully built uboot, xen (4.14.4) and dom0 linux kernel with xen tool stack, these two last starting from buildroot (with linux kernel version 5.15.33 and xen toolstack version 4.14.4)
These are the process of Xen:
177 root    /usr/sbin/xenwatchdogd 30 15
203 root    /usr/sbin/xenstored --pid-file /var/run/xen/xenstored.pid
208 root    /usr/sbin/xenconsoled --pid-file=/var/run/xen/xenconsoled.pid
214 root    /usr/lib/xen/bin/qemu-system-i386 -xen-domid 0 -xen-attach -name dom0 -nographic -M xenpv -daemonize -monitor /dev/null -serial/dev/nul -parallel/dev/null -pidfile/var/run/xen/qemu-dom0.pid
and the driver loaded as a module:
# lsmod
Module                  Size  Used by    Tainted: G
xen_netback            65536  0
xen_blkback            49152  0
Xen and dom0 Image boot up successfully, at the end:
>xl list
Name                                        ID  Mem VCPUs State Time(s)
Domain-0                                    0  1024    2    r-----    4000.3
# uname -a
Linux rockpro64 5.15.33 #3 SMP PREEMPT Fri Apr 15 11:01:37 CEST 2022 aarch64 GNU/Linux
when I try to create a domU domain I have problem with disk backend, I have made several attempts trying with different domU linux and I always get the following error :
Parsing config from ./alpine_xen_domu.config
libxl: error: libxl_aoutils.c:539:async_exec_timeout: killing execution of /etc/xen/scripts/block add because of timeout
libxl: error: libxl_create.c:1608:domcreate_launch_dm: Domain 2:unable to add disk devices
libxl: error: libxl_aoutils.c:539:async_exec_timeout: killing execution of /etc/xen/scripts/block remove because of timeout
libxl: error: libxl_domain.c:1182:libxl__destroy_domid: Domain 2:Non-existant domain
libxl: error: libxl_domain.c:1136:domain_destroy_callback: Domain 2:Unable to destroy guest
libxl: error: libxl_domain.c:1063:domain_destroy_cb: Domain 2Big Grinestruction of domain failed
The last try was with alpine domU linux with the following config:
# Alpine Linux PV DomU
# Kernel paths for install
kernel = "/home/xen/vmlinuz-virt"
ramdisk = "/home/xen/initramfs-virt"
extra="modules=loop,squashfs console=hvc0"
# Path to HDD and iso file
disk = [ 'format=raw, vdev=xvda, access=w, target=/data/a1.img',
        'format=raw, vdev=xvdc, access=r, devtype=cdrom, target=/home/xen/alpine-virt-3.15.3-armv7.iso'  ]
# Network configuration
vif = ['bridge=br0']
# DomU settings
memory = 512
name = "alpine-a1"
vcpus = 1
maxvcpus = 1
thanks a lot in advance
Best regards
Marco
The error message you provided indicates a problem with the disk backend. I think you should check disk backend configuration. Make sure that the disk backend configuration in your domU configuration file is correct. Verify that the disk paths, formats, and access settings are accurate. Also, ensure that the disk files exist in the specified locations.
only up
  Manjaro network problem late 2023 acruhl 1 336 01-19-2024, 11:32 PM
  upgrade problem trying4firstbass 1 795 11-28-2022, 01:44 AM
  u-boot flashing problem dex357 2 2,441 11-27-2021, 04:13 AM
Last Post: dex357
  Ubuntu for RockPro64 dndeokar 1 3,553 08-14-2020, 06:42 AM
  Problem updating Manjaro bceverly 2 4,373 03-19-2020, 09:12 PM
Last Post: spikerguy
  Anyone solve the Akonadi problem? metcalsr 3 4,970 02-08-2020, 11:26 AM
Last Post: wove
  How do I install the Pine64 Installer? leibide 9 8,619 01-16-2020, 12:21 PM
  An interesting display problem has developed Watercourse 2 3,619 11-18-2019, 10:40 AM
Last Post: Watercourse
