Pinebook pro will not run a long stress test of OpenCL
Summary:
  • A stress test of SGEMM (matrix multiplication) using OpenCL will slow down after 150 iterationbs.
    • Details:
      • Test is running fine during the first 100 iterations (multiply two matrix of 512 x 512). It will slow down to 1/2 speed after about 150 iterations, and will slow down farther to about 1/4 speed after 200 iterations, etc.
      • Note: test is running fine if sleeping for 20 seconds after every 100 iterations
Question:
  • Do the Pinebook pro GPU has a hardware problem (ex: over heating) that prevent running a long OpenCL stress test?
Details:
  1. Pinebook pro setup highlights:
    1. Ubuntu 18.04 64bit (based on the root file system from: https://github.com/ayufan-rock64/linux-b...m64.img.xz)
    2. Compiler: gcc 8.3
    3. OpenCL 1.2 (wget --timestamp https://github.com/rockchip-linux/rk-roo..._arm64.deb)
    4. ARM Compute Library 19.11.1 (native compile of sources from https://github.com/arm-software/ComputeLibrary)
  2. [size=undefined]OpenCL is verified with:[/size]
  3. [size=undefined]Stress test:[/size]
    • SGEMM (matrix multiplication) using OpenCL of the ARM Compute Library 19.11.1 - the test code is appended below
// Example code is based on:
// * https://github.com/ctuning/ck-math/tree/master/program/acl-sgemm-opencl-example
// #ifndef ARM_COMPUTE_CL /* Needed by Utils.cpp to handle OpenCL exceptions properly */
// #error "This example needs to be built with -DARM_COMPUTE_CL"
// #endif /* ARM_COMPUTE_CL */
#include <arm_compute/core/Types.h>
#include <arm_compute/core/Helpers.h>
#include <arm_compute/core/ITensor.h>
#include "arm_compute/core/CL/CLKernelLibrary.h"
#include <arm_compute/runtime/Tensor.h>
#include "arm_compute/runtime/CL/CLFunctions.h"
#include "arm_compute/runtime/CL/CLScheduler.h"
#include <cstdlib>
#include <cstring>
#include <fstream>
#include <iostream>
#include <cctype>
#include <cerrno>
#include <iomanip>
#include <string>
#include <sys/time.h>
using namespace arm_compute;
// (MM, MN, MK) can be override from compiler options
#ifndef MM
#define MM 512
#endif
#ifndef MN
#define MN 512
#endif
#ifndef MK
#define MK 512
#endif
int main(void)
 long num_repetitions=1;
 struct timeval before, after;
 unsigned int m=MM;
 unsigned int n=MN;
 unsigned int k=MK;
 if (getenv("NUM_REPETITIONS")!=NULL) num_repetitions=atol(getenv("NUM_REPETITIONS"));
 if (getenv("MM")!=NULL) m=atol(getenv("MM"));
 if (getenv("MN")!=NULL) n=atol(getenv("MN"));
 if (getenv("MK")!=NULL) k=atol(getenv("MK"));
 printf("NUM_REPETITIONS = %lu\n", num_repetitions);
 printf("m = %u\n", m);
 printf("n = %u\n", n);
 printf("k = %u\n", k);
 TensorShape AShape(k,m);
 TensorShape BShape(n,k);
 TensorShape OShape(n,m);
 CLTensor ATensor;
 CLTensor BTensor;
 CLTensor OTensor;
 CLScheduler::get().default_init();
 ATensor.allocator()->init(TensorInfo(AShape,Format::F32));
 BTensor.allocator()->init(TensorInfo(BShape,Format::F32));
 OTensor.allocator()->init(TensorInfo(OShape,Format::F32));
 CLGEMM gemm;
 gemm.configure(&ATensor, &BTensor, NULL, &OTensor, 2.0f, 2.0f);
 ATensor.allocator()->allocate();
 BTensor.allocator()->allocate();
 OTensor.allocator()->allocate();
 gettimeofday(&before, NULL);
 for(int r = 0; r < num_repetitions; ++r) {
   gemm.run();
   CLScheduler::get().sync();
 gettimeofday(&after, NULL);
 double total_time = (after.tv_sec - before.tv_sec) + 1e-6*(after.tv_usec - before.tv_usec);
 double flops = 2.0*m*n*k;
 double gflops = 1e-9 * flops;
 double avg_time = total_time / num_repetitions;
 double avg_gflops_per_sec = gflops / avg_time;
 printf("M = %u\nN = %u\nK = %u\n", m, n, k);
 printf("TIME_TOTAL = %lf\n", total_time);
 printf("TIME_AVG = %lf\n", avg_time);
 printf("GFLOPS_AVG = %lf\n", avg_gflops_per_sec);
 printf("------------- CLBLAST-STYLE_OUTPUT\n");
 printf("m = %u\nn = %u\nk = %u\n", m, n, k);
 printf("ms_1 = %lf\n", avg_time*1000);
 printf("GFLOPS_1 = %lf\n", avg_gflops_per_sec);
 return 0;
(02-05-2020, 01:48 PM)gal_shalif Wrote: Do the Pinebook pro GPU has a hardware problem (ex: over heating) that prevent running a long OpenCL stress test?
Nobody was stressing the gpu as much as you, yet.
Perhaps start with the usual suspects:
Display journal logs in real-time
$ journalctl -f
The kernel includes a thermal driver, maybe it's print something to dmesg?
$ dmesg
Then you can look at the cpu and gpu temperatures. If you don't find a gui, you can look at the sysfs attributes. They might vary depending on the kernel. Here from a modern 5.5 kernel
debian:/sys/class/thermal$ cat thermal_zone0/hwmon?/name
cpu
debian:/sys/class/thermal$ cat thermal_zone1/hwmon?/name
gpu
cat these values in a loop for real-time updates
debian:/sys/class/thermal$ cat thermal_zone0/hwmon?/temp1_input
25000
debian:/sys/class/thermal$ cat thermal_zone1/hwmon?/temp1_input
25000
Let us know your findings.
  Debian on Pinebook Pro u974615 7 1,052 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,617 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,160 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,076 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,250 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,295 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,488 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,595 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 667 07-13-2023, 05:21 PM
Last Post: owaspfap
