How to open the phone?
(02-11-2020, 01:47 PM)quixote Wrote: Edit 5 min later: Well, a knife point worked to get the gap started. Then I used my nail. Still *very* tight and took a lot of coaxing. I think people will need a heads-up to expect this when the general-user-version goes out.
Mate, you're scaring me. There is a notch, specifically there to place your fingernail into (or a blunt and soft tool). You do not need to create a gap! Sorry, I'm not yelling, I'm just trying to make it obvious that there is a purposely made notch to separate the back cover from the phone. It is a bit rigid, but it's all pretty tough, so shouldn't break by you tugging on it.
See this photo, it's on the bottom right of the phone/back cover
.jpg   IMG_20200613_173147~2.jpg (Size: 191.59 KB / Downloads: 326)
I hope this clarifies things
(06-12-2020, 09:56 PM)nationalicon Wrote: There is a tool for this sort of thing, called a "spudger". I suggest a vinyl one (not metal). They are typically very inexpensive.
You could also use a guitar pick. That might be easy to come across for some people. I have no problem using my thumbnail though.
I use two thumb nails in the notch, then go around the whole phone spreading the gap all the way around.
I do have one small crack in mine now because I tried 'gently tugging' after just widening the gap at notch.
IF you slide your nail ( in the gap ) around the whole phone it will pull off easily.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I use a spudger to get the back off mine. Don't want to ruin my nails LOL.
She knows just enough about Linux to be dangerous.
Me ~ Tw: @chernowa
  Phone powers off with high user demands car46999 7 601 04-11-2024, 09:17 AM
Last Post: zetabeta
  various tricks to open the pinephone shengchieh 2 713 03-23-2024, 09:27 AM
Last Post: Ferriah
  Phone will not turn on (but sometimes will) insidetrip101 10 4,810 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 1,076 07-31-2023, 07:50 PM
  No calls on Pine Phone Beta convergence edition polypode 1 1,187 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,132 02-20-2023, 12:14 AM
Thumbs Down Phone is unresponsive theneedful 14 7,697 08-12-2022, 08:18 AM
Last Post: theneedful
  Phone Dead Already? MarsColonist 4 2,695 08-11-2022, 11:52 AM
Last Post: auanta
  PPKB with phone; phone dies while charging SwordfishII 1 1,379 06-08-2022, 04:14 AM
Last Post: SwordfishII
  PWM whine near earpiece in low signal phone call and loud sound sent to the other end vortex 29 26,577 01-14-2022, 11:00 AM
Last Post: eugenr
