various tricks to open the pinephone
What are the various tricks you have to open the pinephone?
In specific, to separate the back cover from the front "brick"
a crack.  [Once I get started, the rest is easy.]
I used to be able to open it.  I have not opened it for over
4 months, so dust, etc, probably settle inside.
The methods I am aware of
1.
Hold the phone upside down, facing your heart.  Put your
right fingernail in the slot and pull toward your right
shoulder.
2.
Hold the phone upside down, facing your heart.  Put a
credit card in the slot and zip right, pulling alittle.
3.
Turn the phone upside down and over, facing desk.  Put
a credit card in the slot.  Slide leftward and pull.
i
Are there any way to clean the slot with the cover on?  I
tried rubbing alcohol and q-tip.
Thank in advanced for any help.
Sheng-Chieh
I finally got the pinphone opened.  Yay!  What a pain in the neck.
Needed to since I got a power problem, but don't worry about this -
I start a new post if needed.
What I did is use a screwdriver where the tip is about the same
thickness as the slot.  Push down, alittle to the right, and pry
it opened.  I do >>> NOT <<< recommend this unless you are desparate
to open the pinephone since you will dent the slot.  I.e. try the
3 methods in the OP first.
Now the issue is how to make it easier to open the pinephone again
and again and again.  Beside the slot, there is plastic "pins" about
1/2" from the slot on the back cover and there is a "hole" about
1/2" from the slot on the front part.
I already
1. cleaned the "pins", "hole, and slot.
2. filed the "pins" a tiny weeny bit (still want cover to snap on).
Any other suggestion?  Will lubrication on plastic work?  Will
removing some "pins" help?  If so, which one?
Thank in advanced for any help/tip.
Sheng-Chieh
my pinephone is really easy to open, but that is because I had to take the battery out whenever it froze. the more you open it the easier it gets to take off the back. mine opens sometimes when I'm just trying to take the case off lol
  my pinephone melted norayr 6 815 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,076 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 331 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,776 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,630 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,378 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 969 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,080 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,434 07-23-2023, 03:49 PM
Last Post: kb-zealot
  Using optical drives with Pinephone cdforever 2 1,196 07-18-2023, 01:28 PM
Last Post: cdforever
