PPKB with phone; phone dies while charging
Hoping someone can help me out.
Running Arch, on my pinephone in the keyboard case. The keyboard case works fine, even got the top row symbols working.
 I did megi's echo 1500000 > /sys/class/power_supply/axp20x-usb/input_current_limit
Problem is after using it, I plug it into a charger and the next morning the phone is dead. I have tried 5 different chargers including dumb 2.4a. This has occurred on every distro I have tried (all of them except manjaro).
Any ideas?
Edit: I should add that when not on ac power the keyboard charges the phone just fine, so it doesn't seems to be the pogo pins
(05-31-2022, 06:47 PM)SwordfishII Wrote: Hoping someone can help me out.
Any ideas?
After buying 3 different chargers and cables, both PD and dumb with stated 3A 5V, testing all the ones I already had, none of which worked with the pp+kb, I remembered that the Pi 4 has weirdish (high) power requirements (and does not conform to PD), and usb-c. Plugged that special powersupply in and it charges the whole package! On Arch too!
(At least in my case) A Pi 4 specific powersupply is the answer
  Phone powers off with high user demands car46999 7 582 04-11-2024, 09:17 AM
Last Post: zetabeta
  Phone will not turn on (but sometimes will) insidetrip101 10 4,758 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 1,060 07-31-2023, 07:50 PM
  No calls on Pine Phone Beta convergence edition polypode 1 1,174 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,130 02-20-2023, 12:14 AM
  Charging Indicator On - Not Charging SJSEng 0 790 08-30-2022, 07:33 AM
Last Post: SJSEng
Thumbs Down Phone is unresponsive theneedful 14 7,640 08-12-2022, 08:18 AM
Last Post: theneedful
  Phone Dead Already? MarsColonist 4 2,681 08-11-2022, 11:52 AM
Last Post: auanta
  Battery mot charging past 54% StickyPine 32 26,203 02-26-2022, 02:07 AM
Last Post: vusra
  PWM whine near earpiece in low signal phone call and loud sound sent to the other end vortex 29 26,390 01-14-2022, 11:00 AM
Last Post: eugenr
