Blank Screen after reboot
(01-27-2020, 08:20 AM)Sats Wrote: I have plasma on the sd card.  I also have the sd img on the card and neither boot.  Should I DD the emmc img into a new SD card and try booting from there?  Thanks.
If you're comfortable enough using dd, I'd advise just dding the same image you used to make your SD. The installer imgs aren't actually necessary.
someone more familiar with manjaro might be able to help you better...
my input would be make a minimal debian install to a different sdcard using danielt's installer. you should be able to do so from any linux machine. i suspect this will boot knowing it has the updated uboot code.
Thanks!
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Video Flashing/adjusting on boot and reboot jbradley419 0 290 01-16-2024, 09:17 AM
Last Post: jbradley419
  Black screen by start up bluedemon382 10 2,967 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,019 04-01-2023, 07:55 AM
Last Post: hacknix
  PBP green LED works but blank display. frerebo 1 877 02-22-2023, 03:11 AM
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,000 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,096 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,749 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 4,751 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  Vertical Grey Bars on PBP Reboot MickTheGeek 5 4,843 06-04-2021, 02:43 AM
Last Post: dsimic
