PBP green LED works but blank display.
Hi, recently ordered pinebook pro. For the first couple days it worked just fine, and then one day the display just completely stopped working. As far as the green LED is concerned, it powers on and off just fine whether plugged in or on battery.
Sorry I'm new to this, but here's what I've done so far (spoiler alert none of it has worked):
1. Took the base off, and hit the reset button (and I made sure the emmc module switch was on).
2. Demonstrated my Galaxy brain intellect by taking the base off again, disabling the emcc switch, spent 5 hours backing up several years of important stuff stored on my SD card, flashed Armbian to the SD card, and then realized the PBP doesn't actually have a full sized SD slot. Turned emmc switch back on.
3. Downloaded Manjaro, wrote it to a USB drive using https://gitlab.com/bztsrc/usbimager and tried to boot that way.
4. Connected a USB-C cable to a USB-C monitor.
I'm still a bit lost on all the USB versions so I'm not 100% sure if the USB-C cable I grabbed supports DP alt mode, but I'll double check that when I get off work here in a few minutes. If that doesn't work, my next idea is to redownload Manjaro, flash it to a USB drive with Etcher, disable the EMCC switch and attempt to boot that way. aaaand if that doesn't work my next thought would be to take advantage of the 10000 mAh battery and thin metal container and use it as a desktop hotplate/coffee warmer. That's not exactly what I had in mind when I ordered it though, soooo any suggestions would be greatly appreciate.  Big Grin
Most likely you got a Manjaru update that doesn't work.
And since Manjaru comes with a funky U-Boot that won't boot to micro-SD, you'll need to disable the eMMC to boot to one.
:wq
[ SRA accepts you ]
  PinebookPro Display Corrupts/Cuts Out Twig 5 2,246 06-11-2023, 07:59 AM
  PBP blank screen after updating Manjaro Franko 6 2,024 04-01-2023, 07:55 AM
Last Post: hacknix
  Finally... The touchpad works great! dsimic 111 140,409 03-13-2023, 09:41 PM
Last Post: kellrobinson
  Lost my second display WEF 5 3,024 08-18-2022, 07:53 AM
Last Post: josmo
  Issues with External Display After Recent Update reundo 0 1,382 11-18-2021, 06:37 PM
Last Post: reundo
  No Display on PBP PitCritter 2 2,288 09-04-2021, 12:05 AM
Last Post: lot378
  Pinebook Pro - Display cable broken? snokis 0 1,522 08-17-2021, 11:30 AM
Last Post: snokis
  pinebook pro dock display out mamboman777 0 1,518 07-29-2021, 10:41 AM
Last Post: mamboman777
  USB C dock with internal display mirrored to projector and one extended display jbrock 4 3,088 07-19-2021, 04:00 PM
Last Post: jbrock
  PBP won't boot (no amber or green LED) ian-s-mcb 46 38,394 04-15-2021, 09:58 AM
Last Post: SnowyMountainWeb
